Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
On my televison the f connector which is the antenna/cable connector broke off. we then put it back and now the tv doesnt turn on. could you please give me some advice.
  • 10,865 Answers
Hi. Begin by unplugging the TV and plugging a blow dryer or a lamp into that outlet to be sure you have power there. If you do, good. If you do not, reset the circuit breaker or replace the fuse.
Now regarding the f connector. The only way to repair one that broke off is to solder a new one into place. If you did that, good. If not, remove it again as it is probably pushing on another component and causing your other problem. Joe
Posted on May 01, 2010
Installing an inside antenna
You can leave the input from the Roku hooked up, hook the antenna to the round connector that says antenna or cable on the tv then select cable or antenna as the input on the TV and select auto scan and let it scan for live chanels and store them...you can switch back and forth between the HDMI input for the Roku and the cable/antenna using the input button on the TV, you won't need to unhook or re hook anything to go from one source to the other.
Mar 16, 2018 | Roku Televison & Video
I hava a small electown tv here in the Philippines. It works fine if a cable provider is connected to the TV. With out a cable provider, connect just a TV antenna. I can get any channel. help pls
go in to menu settings and do a retune to whatever you have there analogue or digital from your antennae make sure your antennae is good and the coax cable connectors is ok
Mar 12, 2018 | Televison & Video
How do i get my Dynex TV to work on an antenna
Easy. First put up a good outside or wall antenna. Then run a coax cable (not flat lead wire) from the antenna to the tv. To do this you need to get a "balum" to go from the antenna to the coax wire. It's a small plastic 'transformer' (( about the size of your pinky finger)). The other end of the coax wire should have an 'F' connector put on it so it can screw into the F connection on the back of the tv set. Then get your remote and go to the input of your tv and change it to antenna input. Then do a channel scan. Let it finish scanning and it will let you know how many channels it picked up. If you're in a big city then you may pick up as many as 100 or more channels. If you're in the country, you may only pick up about 5 channels! If you need more channels then go back to Home Depot or Lowes and get an 'antenna amplifier'. Hopefully one that has about 25db gain. Most only have about 10db gain but the higher the number the better. It should be put inline between the tv and the antenna so you'll need another coax cable for the amplifier to the tv. The wire that comes from the antenna goes directly to the 'input' of the amplifier. Then from the 'output' of it to the tv. You'll love it once it's done and it's cheaper than cable or any other paid service!
Aug 17, 2017 | Dynex Televison & Video
Can you hook up the tv directly to the antenna? We do not have cable. If so what kind of cord/cable do we need?
That will depend on what sort of antenna you have. Radio Shack will have a flat wire to F connector if that's what you need. if you are in a urban area, I'd suggest a leaf type antenna. I personally use Mohu brand amplified ones on each tv. No more cable bills,
Feb 11, 2017 | Televison & Video
How do I hook up an indoor antenna to my Sanyo TV
There is a threaded connector marked cable/antenna. You use this connection to attach the antenna cable. Then you do a channel scan with the tuner set to antenna not cable.
Nov 21, 2016 | Sanyo Televison & Video
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
No signal on samsung 40"lcd tv
IF it is an ATSC tuner ,newer type ,( digital tuner) it needs better antenna, most importantly Check the cable from Antenna to the connector. using multimeter , put on resistance ,any, anc check both ends of the cable, when there is no change on the multimeter consider the wire is broke somewhere. Make sure the antenna is pointing towards the tv station. also check www.antennaweb.org i think to see the DTV channels in your area. GL
Apr 08, 2010 | Televison & Video
VHF/UHF cable connector broke off from back of televison
well it can be fixed but you will need rf connector their cheap send it to a tv shop they will fix for 30-50 bucks sorry
Apr 03, 2009 | Televison & Video
Need an antenna block for a Sanyo DS25390
Was the block a cube about 1" ? You should be able to salvage one from an old tv. This block is used to isolate the antenna/cable from the "hot" chassis inside your tv. If you should find a used block ,make sure it does this. If you get one that gives you a direct connection to the chassis, your antenna/cable connector would give you a shock and probably burn out something in your tv when the cable is connected. Some of the Sanyo's have this connector made on to the tuner. If this is the case you'd have to either put a new coax connector in the tuner OR replace the tuner. Stargazer
Jan 23, 2007 | Sanyo DS25390 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
23 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
