Question about Samsung SGH-Z720 Cellular Phone
The lcd of m samsung z720 doesn't lit. but the keypad has a backlight on it. what is the most probable cause of this problem?
  • Samsung Master
  • 6,993 Answers
there is nothing wrong with your LCD, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Posted on May 01, 2010
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
Tip
Shwo me how to diss assemble samsung z720
When Logged in or After U insert PenDrive -
Just Open WinRAR and go to ur Drive -
Der U will find the Files with Virus.
Named>Autorun.inf and some other Rubbish file with .Exe
Delete Both the Files from it-
Play Safe-
Thank Meeeeeeee Friends !
on May 06, 2011 | Samsung SGH-Z720 Cellular Phone
Samsung lcd tv
The problem is the main board.
Apr 17, 2017 | Samsung LN52B630 52 in. LCD HDTV
Where do i find a bulb for it
There is no bulb. The LCD screen is lit by a backlight. You can check on ebay for a backlight. Good Luck
Nov 24, 2009 | Samsung SyncMaster 203B LCD Monitor
How to instal java aplication on samsung sgh z720?? like ebuddy.jar pdenglish.jar operamini.jar and many more??
if you have GPRS/EDGE connection then use built in web browser and go to miniopera.com and follow onscreen instruction.
Aug 25, 2009 | Samsung SGH-Z720 Cellular Phone
Is there any way of turning on the backlight on the numeric keypad on the u600?
From your main menu go into "Settings". Select.
Scroll down to number 5 "Light settings. Select.
Scroll down to number 3 "Keypad light". Select.
It will probably be set to "Night time" 05:00 PM.
Use your direction pad to change it to "Any time" Save.
The keypad backlight will be on all the time.
Aug 17, 2009 | Samsung SGH-U600 Cellular Phone
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Keypad backlight function turns off when call is connected
Plain and simple there is something wrong with the LCD on your phone, needs to be repaired if possible
Mar 13, 2008 | Samsung SCH-u740 Cellular Phone
Backlight Problem
look under power management let me know wont you?
Mar 12, 2008 | Sony Ericsson K800i Cellular Phone
Samsung SGH-Z720 Cellular Phone Logo
147 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
