Question about Gaggia Classic Espresso Machine
Gaggia Cubika: no pressure, no coffee comes
Since 2 days my Gaggia Cubika makes strange noises while heating up and then there's almost no pressure for the coffee so I have to wait up to 30 sec. for the coffee to come; sometimes no coffee comes at all (the coffee-powder is not grinded too fine!). The milk-steaming works perfectly well! It sounds like boiling-bubbling, but much louder as usual. Can anybody help me?
    President:
  • 1,618 Answers
The machine needs to be descaled.
Posted on May 04, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
Turn machine upside down. Undo Phillips screw, remove metal disc filter plate. Clean the small holes with a pin. Rinse under water then replace.
Posted on Feb 07, 2016
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
I don't have an instruction book with my Gaggia Cubika and I can't find one online. Help? Elaine
http://www.coffeeitalia.co.uk//prodimages/manual/gaggia/24_cubika.pdf
There you are..
enjoy
Feb 06, 2010 | Gaggia Classic Espresso Machine
There is no steam coming out of the spout....CUBIKA GAGGIA...and it steams from the main body of the machine. please help!! Thanks
Check the end of the wand that might be blocked, use a paperclip to clear. If that does not work then the valve needs to be replaced.
Oct 27, 2009 | Gaggia Classic Espresso Machine
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
Water coming out of steam nozzle not coffee output when making coffee
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
May 12, 2009 | Gaggia Syncrony Compact Coffee...
Coffee runs slolwer than before, not enough pressure
i hope i can help you?. please check the filter make sure its clean. and not damaged and check where the coffee comes out for any blockage
May 06, 2009 | Gaggia Classic Espresso Machine
Gaggia cubika, weak coffee.
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Nov 08, 2008 | Gevalia 35411 / 50433 Coffee Maker
Wiring diafram for Gaggia cubika
What kind of Gaggia do you have?
Jul 10, 2008 | Coffee Makers & Espresso Machines
Gaggia Classic Espresso Machine Logo
1,296 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
