Question about Garmin eTrex Vista HCx Handheld GPS Receiver
For compatibility with Swiss maps using CH1903 and WGS 84 should I set my Garmin hcx to UTM UPS with WGS84 or Swiss Grid with CH 1903 ?
  • franmcg May 02, 2010
    Have found the answer: Swiss Grid
  • 4 Answers
Say to god
Posted on May 01, 2010
On google plus it allows you to share your location with whom ever you choose, so my husband and I share our location with each other, but for some reason his is always wrong, and it always shows him in...
Hi Brenda
You need an App that will give you your current GPS coordinates.
Install an App Like MotionX or similar. Check the Latitude & Longitude or Better still the UTM Easting & Northing (same thing but UTM is the new digital coordinates & is easier)
Compare one phone coordinates with the other phone.
they should be almost identical if your in same location.
Otherwise check your phone SETTINGS for GPS & how it's set up.
Even a standard Garmin GPS tracker (which I use for prospecting) can be set fro the wrong side of the world. Usually its set for WGS 84 or 94 & UTM. I have seen people set up for the northern hemisphere when they are in the southern hemisphere.
Also, you said that your husbands settings never change. Well... it's GPS either turned off or broken.
I also use my "Find My Phone" App to check on the wife.... and she's on her way home... so GoodLuck
Cheers
Trevor
PS
Poor choice of Brands.... but thats another story.
Aug 06, 2014 | Cell Phones
We are trying to set up our Navigation options correctly on our Triton 500. How should we have them set up? We are in the USA, Idaho.
In the USA you would set: Lat/Long as Deg.min.sec or UTM .. Compass at True North and Datum at WGS84. This assumes that your maps were constructed at datum WGS84 which is current standard.
Jun 20, 2010 | Magellan Triton 500 Handheld GPS Receiver
Consistent error entering garmin etrex coordinate in google earth
Consistent errors are usually projection or datum related. If you are taking coordinates collected in one projection and displaying them in your GPS in another, you the points will offset. I'm not talking about the decimal degrees 00.000n 000.0000w vs 00 00 00N 00 00 00W. I'm talking about the geographic model to represent the surface of the earth. Google Earth generally uses a geographic projection with WGS 1984 or WGS84 Datum. Make sure you are using the same settings on your GPS.
Apr 09, 2010 | Garmin eTrex Legend GPS Receiver
How do I install maps from the Garmin US Topo 100K to my Garmin Etrex Vista HCx? I've put in a microSD card, then what?
You need to install the map software on your PC. From there, using the map select tool, select the maps you want to add to your GS unit and then send them to the microSD card which will show up in the SEND window.
Mar 29, 2010 | Garmin eTrex Vista HCx Handheld GPS...
Grid reference
If you mean the WGS or MGRS grid reference, you have to change it in the 'navigation' options.
Dec 25, 2009 | Garmin eTrex Legend GPS Receiver
I need to use the garmin etrex in italy - which grid system do I use?
I use always UTM/MGRS. It works all over the world. Just need to check that the maps support this.
May 10, 2009 | GPS
My map on my garmine 60csx doesnt line up with the actual locations
The most common cause of consistent offset is DATUM selection. The DATUM was likely set to WGS84 at the time of recording then viewed later in NAD27, or vice versa.
Geocaching.com uses WGS84. The USGS generally uses NAD27
Also see this Garmin page. The DATUM is set under Settings | System if I recall correctly.
Oct 22, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin Etrex - ORdnance Survey Grid reference nos
You shouldn't have to connect to a computer. I don't have an OS map in front of me but I'm guessing they use UTM with a WGS 84 datum (if the map was produced after 1984 that is). Got to the Setup page then select Units. Change Position Frmt to UTM/UPS and Map Datum to WGS 84.
Jul 29, 2008 | Garmin eTrex GPS Receiver
Toggling between lat/long and grid references
I eventually solved the problem by firstly doing a restoration of default settings. This allowed me to toggle but it was between two different presentation styles of latitude and longitude. To restore the grid co-ordinates option I went to main menu, the Setup, then then toggled to location and re-selected UTM UPS as the location format.
Apr 27, 2008 | Garmin GPS 72 GPS Receiver
Using French grid reference system
UTM GPS position format, WGS 84 datum point if my memory serve correctly
Feb 19, 2007 | Garmin eTrex GPS Receiver
Garmin eTrex Vista HCx Handheld GPS Receiver Logo
126 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
