Question about Maytag HYG3460AWW Gas Dryer
Drum will not turn dryer gets hot
How to access belt
    New Friend:
  • 107 Answers
If you hear the motor running; then most likely the belt has broken.
Posted on May 01, 2010
Kenmore 80 series the drum will not turn but dryer gets hot
more then likely, the belt broke that turns the drum.
Jan 24, 2012 | Kenmore Dryers
The blower on my dryer needed to be replaced, I replaced it. Now the dryer gets hot very quickly, but is not tumbling. The belt looks worn but is still intact. I don't know anything about dryers! Do I...
If the drum was turning or if the blower caused it not to turn before you replaced the blower make sure the blower and the motor will turn maybe didn't get something back right. Did you clean all the lint or anything out of the blower housing and the vents. Recheck the idler pully and be sure the belt is threaded right. I have seen this happen and drum would't turn. If it's getting too hot sounds like the air is not getting pulled through the drum or the high limit is not shuting it down when it gets too hot . Check all thermastats and the high limit cut off. You can check them with a ohm meter. Check and see if you can turn the drum by hand.
Hope something here will help you.
Dec 05, 2010 | Maytag Dryers
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
The dryer gets hot but the drum does not turn
sir please check the motor is running and this will be fixed inside the dryer and a belt will be fixed which makes the drum to rotate when the motor starts.so you should check both the belt and the motor.
Sep 04, 2009 | Hotpoint Aquarius WD640 Front Load...
Dryer not turning
remove top cover and then front to reveal drum and belt,to repl belt lift up drum and install belt around drum and then on mtr and idler pulley then reinstall frt and top cvrs
Jul 11, 2009 | Whirlpool Dryers
Frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Jun 03, 2009 | Frigidaire FER211A Electric Dryer
The dryer will get hot but the drum will not go around
More than likely, the belt is broken. Otherwise, the drum motor is shot. (That's not very likely though).
Apr 22, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer heats up, drum won't turn. any suggestions?
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Feb 12, 2009 | Bosch Axxis WTA 4107 Electric Dryer
Maytag HYG3460AWW Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
