Question about Jabra Audio Players & Recorders
Jabra 250bt beeps continuously - Jabra Audio Players & Recorders
Resetting my jabra extreme 2
If your Jabra Extreme2 Voice guidance is not turned on - i.e. you only hear beeps when you power on or a call comes in...
Cause: powered on or off with answer button depressed
Solution:
1) Power off
2) Hold down answer button (the one that lights up Jabra)
3) Power on
4) Release answer button
You may need to repeat.
Jan 24, 2013 | Jabra Extreme2 Bluetooth Headset
I purchased a new Iphone and my Jabra will not pair. I removed the Jabrsa connection from my old iphone and the Jabra still will not connect. How to reset Jabra and pair new phone?
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
Nov 12, 2010 | Jabra Cruiser InCar Speakerphone Black
Jabra bt160. fully charged, unit will not turn on?
On my unit and it is older, I have to hold the button for a bit before it comes on. Should beep in your ear..
Feb 21, 2010 | Jabra BT160 Wireless Headset
Jabra OTE1 pairing problem
Every time i turned my jabra on the three beeps are in slow motion why?
Aug 15, 2009 | Jabra BT250 Consumer Headset
I have lost instructions from my Jabra BT250 and can't remember how to pair? my new phone is a htc
switch off jabra. Hold down on/off button for sabout 10 secs until blue light is continuously on. Then pair from the phone. Pin 0000
Jul 05, 2009 | Jabra BT250 Consumer Headset
Beeping sound
if you use phone without headset do you hear beeping?
Jan 11, 2008 | Jabra BT500 Wireless Headset
Jabra BT125 Bluetooth
First u switch off the Jabra Headset..
then switch ON the Bluetooth in ur Cell.
then search for active devices in your cell..
while searching switch ON the bluetooth Headset.press and hold it continuous until the light is on.
you must hold it for approx 15 sec..
then the jabra wil be displayed in your cellphone....
tats it....add it....
enjoy,,
Nov 28, 2007 | Jabra BT125 Headset
Cant hear
I have the same problem. The lights are on, it's paired, and my caller can hear me. but I cannot hear the beep from pressing buttons on the jabra, nor can I hear anything from the phone.
Oct 31, 2007 | Jabra BT500 Wireless Headset
60 people viewed this question
Top Jabra Audio Players & Recorders Experts
Tom Chichester
Mister Danger
Jeff Tilburn
Jeff Tilburn
Are you a Jabra Audio Player and Recorder Expert? Answer questions, earn points and help others
