Question about HP Compaq Presario SR1230NX (PJ518AA) PC Desktop
Is this computer pci express x16 video card compatible?
So no problem here, just a question. I need to access two monitors off this box and before I purchase a radeon X1050 series video card, I need this question answered.
thanks.
    Brigadier General:
  • 6,966 Answers
To my knowledge it does not have PCI Express but standard PCI only. For an add-on video card, it has an 8X AGP slot.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 25, 2008
    President:
  • 2,351 Answers
Hi mtribbia, yes the Radeon X1050 has two DVI output connectors. Using ATI/AMD's Catalyst Control Center is where you set up your two monitors. This is known as display extension. Where you can extend your display from the primary 1 monitor & drag the image to your second monitor 2. Download the latest Catalyst Control Suite from here.
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
To change the Catalyst Control Suite to another OS use this link. http://ati.amd.com/support/driver.html
Good Luck & Kind Regards.
Mike
Use of PCI-e x16 slot for non-video card
...........................................!O_O!...........................................................
WHY would you want to do that?
There is a PCI-Express x1 slot on the motherboard.
Black in color, and in-between the black PCI-Express x16 slot, and a white PCI slot.
Use the PCI-E x1 RAID adapter card in the PCI-E x1 slot, and a PCI-Express graphics card in the PCI-E x16 slot. Sheesh!
A PCI-Express slot is not an evolved PCI slot.
Completely different technologies.
PCI uses a shared Parallel bus architecture, while PCI-Express is based on Serial point-to-point.
So your idea of how to 'fix' your problem, is to use a PCI-E x1 card in a PCI-Express x16 slot, and a PCI graphics card in a PCI slot?
Completely backwards.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
PCI-Express x16 slot uses the same lanes from the Northbridge, as the OnBoard video?
UTTER NONSENSE!
The Northbridge chip handles the Faster capabilities of a computer.
Handles the Processor, Ram Memory, and HIGH-SPEED Graphics.
HIGH-SPEED graphics is the Accelerated Graphics Port (AGP) technology, and the PCI-Express technology.
The Southbridge chip handles the Slower capabilities of a computer.
The PCI bus is one of those slower capabilities handled by the Southbridge chip.
The PCI bus is also a shared bus. This slows data down.
The AGP bus, and PCI-Express bus are Not shared. They also have a direct link to the Northbridge chip.
The PCI Bus has to go through the Southbridge chip, which has to go through the Internal Bus, THEN to the Northbridge chip.
OnBoard video, or Integrated Graphics, uses the PCI bus.
When you inserted the PCI-E x1 RAID card in the PCI-Express x16 slot, and a PCI graphics card in the PCI slot, BIOS just assigned another IRQ for the PCI-Express x16 slot.
(Interrupt Request)
No fancy technology going on there.
Backwards technology going on with a PCI-Express x1 card in a PCI-Express x16 slot, though.
I do not concur, and do not think that is a good solution, Kevin.
Regards,
joecoolvette
Aug 24, 2012 | Gateway Foxconn C51GU01 Motherboard
What is compatible graphic card for A740GM-M
Any PCI Express x16 or PCI Express v2.0 x16 card show work provided your power supply can handle it and that it's no too big for your case.
Jun 06, 2012 | EliteGroup ECS A740GM-M Motherboard -...
Hi, i have a pc chips A15G board and i want to know if i can use a video card pci ex x16 2.0 or only can use pcie x16
you can use 2.0 as its backwards compatible you wont get the same thorough put (speed from the 2.0 specification) but you will be fine. hope this helps
May 14, 2011 | PC Chips PCChips A15G Motherboard - v1.0,...
What video card are compatable with SR1620NX ? The graphics card is not working right anymore and I need a compatable video card.
A PCI Express graphics card.
Doesn't matter if the PCI Express graphics card uses the PCI Express 2.0 technology, or the PCI Express 2.1 technology.
The PCI Express graphics card, will insert into the PCI Express x16 expansion slot on the motherboard.
Supporting data;
1) View of the motherboard in an illustration,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1127351
Scroll down the page to view the motherboard illustration.
A) Looking at the illustration, view the BATT. (CMOS Battery)
To the left of the CMOS Battery (BATT) are three white PCI slots.
Above them is a longer expansion slot. This is the PCI Express x16 slot.
Above it is marked > PCIX16X1 (PCI x16 times 1 slot)
NOTE* When installing the PCI Express graphics card, lift up gently on the Lock 'handle'.
It looks as though you should push down on it, but you need to lift up on it instead.
Also go above the motherboard illustration, and read to the right of the heading > Internal Connectors
In the list you will see > One PCI Express x16 graphics slot.
WHEN installing a graphics card, ALWAYS install the software from the CD disk provided, First!
Computer on, and Windows running, insert the graphics card's Installation disk, (CD) into the optical drive tray.
Install the software by following the directions.
THEN shut the computer down normally, and unplug the computer from power.
OBSERVE Anti-Static Precautions.
Install the graphics card.
Close the computer case, and plug the monitor into the graphics card.
Turn the computer on.
When you install a device (Such as a graphics card for example), Windows will try to find compatible drivers.
IF, THE driver is not installed First, Windows will match up one of it's thousands of generic drivers.
This = No.
You want THE driver installed first, so that Windows will find it, and Not try to match on of it's generic drivers.
NOTE 2*
It DOESN'T MATTER what graphics ram memory the graphics card has.
The graphics card's Processor and Ram Memory operates independent of the system resources.
Example:
The computer uses DDR Sdram ram memory.
The graphics card uses GDDR5 graphics ram memory.
It will work just fine.
NOTE 3*
It does NOT matter if your computer uses the PCI Express 1.1 technology, and the graphics card uses the PCI Express 2.0, or 2.1 technology.
PCI Express 2.0, and 2.1 technology is Backward Compatible with PCI Express 1.1 technology.
Will you get the full capability of the PCI Express 2.0, or 2.1 graphics card?
NO
Will you notice?
NO
What you need to look at it, is how much power will the graphics card use. Look at the system requirements for the graphics card, and be sure your Power Supply has enough power for that graphics card.
Also, IF, the graphics card requires additional power cables from the Power Supply, make sure your Power Supply has the required power cable, or power cables.
IF the Power Supply does not, use a power adapter cable.
NOTE 4*
Graphics card manufacturer's base the power needed for the graphics card, Not just on the graphics card itself, but on an entire computer system, AND the graphics card.
The graphics card manufacturers use a test computer system, that is a powerful computer system.
Gamer motherboard, Dual Core, or Quad Core processor, 4GB of ram memory, and at least two harddrives, and two optical drives, PLUS the graphics card in question.
This complete computer system uses a LOT more power than just the graphics card by itself.
There isn't a single graphics card out there, that uses more than 150 Watts by itself.
Recommendations for a graphics card that is compatible, with a Compaq Presario SR1620nx desktop computer?
Budget to medium:
Good enough to watch videos, older games, and some newer games.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675217&CatId=3670
Medium:
Higher level games, and large screen monitors,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6642574&CatId=3669
For questions post in a Comment.
Regards,
joecoolvette
Dec 18, 2010 | HP Compaq Presario SR1620NX...
Can i use a pci express x16 video card and a standard pci card?
yes you can use a AGP or PCI video card install the driver and enable the monitor in your video settings, also ensure you remember to enable the tv setting in your video card properties.
Mar 26, 2010 | Jaton NVIDIA GeForce 9400 GT, PCI Express...
Is there any video card compatible to my ASUS p5rd1-vm ?
You ASUS mother board has 2 PCI slots.
1 PCI Express x16 <- this 1 is for video expansion
1 PCI Express x1
Jan 08, 2010 | ASUS P5RD1-VM Motherboard
What pci card will fit
if your computer is a SR1620NX the support site on compaq tells you what you need http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&lc=en&dlc=en&cc=us&lang=en&product=1127351
go down to expansion slots and it says
  • One PCI Express x16 graphics
  • Three PCI
  • One SCSI connector for PCI Extender Card for two additional PCI slots (optional)
so if you want to put a graphics card in you need a pci express card or a pci card
Jun 01, 2009 | HP Compaq Presario SR1620NX...
I need help choosing a video card.
Hi there.
Any PCI Express card will do as long as its DDR2, DDR3 is not supported by your motherboard.
You have a choice between ATI or Nvidia graphics cards and your system should support up to 1GB of graphics memory.
Good luck and thanks for using FixYa!!
May 13, 2009 | Intel D101GGC Motherboard
Graphics card compatibility
That mobo is here"
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138090
It says it has a PCIe x16 slot, so really good graphics cards running on PCIe x16 will work on it.
This is a list of the PCI express x16 cards you can buy:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010380048%201069609641&name=PCI%20Express%20x16
Generally the more they cost the better the performance but that is another story =)
If you wanna to hit me up with your full PC specs of CPU, RAM, Windows version, etc, i could recommend cards for certain games.
It also has PCI so older and less powerful PCI cards can likely be used.
Mar 19, 2009 | Computers & Internet
Adding a video card to dell dimension 4700 desk top
hello
you need a pci express X16 graphics card
here is your computer specifications
here is a good card.
and here you have more.
most important is that the card is pci express x16 compatible
good luck and happy gaming.
Nov 26, 2008 | Dell Dimension 4700 PC Desktop
HP Compaq Presario SR1230NX (PJ518AA) PC Desktop Logo
197 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
