Question about Lowrance LMS-332C GPS Receiver
Wont power up
Have re-wired & tested fuses unit wont pwoer on
  • 4 Answers
Say to god
Posted on May 01, 2010
03 civic with new battery and terminals won't turn over and has no power except to the brake lights, what am I missing?
Have you checked fuse's # 19 & 20 40 & 80 amp fuse's . Located in the under hood fuse/ relay box. Also the ELD unit electric load detection in the under hood fuse box . Do you have an know how to use a DVOM - digital volt ohm meter ,how to read a wiring diagram ? http://www.bbbind.com/free_tsb.html free wiring diagrams . Watch a few videos on yourtube for basic automotive electrical testing , Look at electrical distribution wiring diagram , start at the battery , check battery voltage , check at power distribution box Fuse's . Can you do that ? Honda ELD Is the B+ voltage at the I/P fuse box . Check B+ voltage at the ignition switch . Only U can find the problem by electrical testing , we would only be guessing .
Mar 02, 2017 | Cars & Trucks
How do I wire external amplifier
In order for this to work correctly you need:
  1. Power wire (with fuse) from battery to amp (+)
  2. Ground wire from amp to car chassis. (-)
  3. remote-on lead from a 12V power source that turns on and off with the ignition if the head unit does not supply a wire. (switch)
  4. RCA connection from head unit to the amp. (sound in)
  5. Speaker wire connection from amp to speakers. (sound out)
It is easiest to start with deciding on the amp mounting location, and then running all the wires. Add an extra foot or so to each wire. You may discover in the process that you have to move things around due to unforeseen obstacles. This extra foot will help in that case. Always attach the ground wire to the chassis first and then to the amp first. Once you have the fused power wire from the battery installed; remove the fuse before trying to attach it to the amp. ONLY re-install the fuse once all connections to the amp are made, secure, have been checked twice and you're ready to test it.. This includes speakers. DO NOT for ANY reason have the amp powered up before attaching ALL speaker connections.
Feb 23, 2015 | Panasonic CQ-C1100U CD Player
My son bought an amp and subs for his truck. they are second hand without install instructions. I've never hooked up an amp before. This amp xterminator xt1000d has a center port between the positive and...
The 'remote' terminal is powered by a lead that is normally connected off the head unit...if it has this feature...the head unit, if a good quality one' will have a blue wire that will turn on the amp, by providing a signal to it.........if not, you can bypasss this
Sep 20, 2010 | Car Audio & Video
It wont get power
Check the primary fuse on the positive amp wire usually located near the + battery post. Also check any onboard fuses. If these check OK, make sure the remote lead has 12V+ on it when the head unit is turned on. If these all check out, the amp is most likely defective.
May 16, 2010 | American Pro VS1405 Car Audio Amplifier
AMP WONT TURN ON
Hi.
A short on Amp power contact can blow the internal power adapter. Before deciding if to replace or repair the amp, check if it has an external fuse mounted at the back side of the amp. In that case replace it.
Also ensure that the wires that you are connecting to the amp are still powered. Read Volts on wires before connecting to test the amp.
If the Amp has blown, then the damage will be located in the power supply circuit, and can be repaired testing and replacing few components.
Mar 27, 2010 | Crunch Maxxsonics PZi 550.5 Car Amp
1997 chevy tahoe pwoer lock inop. need wire
mite want to ck wires that go between door & door jam,,mite be broken wire?? just a thought,,
Jan 27, 2010 | Chevrolet Tahoe Cars & Trucks
Fuse blew on on cable coming from batter, replaced fuse now my kenwood excelon ddx7015 and amp xxv-02a wont power up , but when i test the fuses they have power
What size fuse are you using? You need a 30-
amp at least and #8 to #10 wire I would go
with the # 8 maybe lower, if it blows a fuwse
now you have a shorted output in your amp.
May This Will Help.
Sep 08, 2009 | Kenwood XXV-02A 4 Channel 25th Anniversary...
Why doesnt my 2400 watt amp turn on?
The size of the wire affects the performance of an amp, but the amp should still turn on. 12 volts is 12 volts. So you tested with another amp, on the same wires, and it works fine.The only thing you can really check on the new amp is the fuses in the side. If those are blown, then you should be able to (Unless the amp is fried, and that's why it blew the fuses in the first place) fire it right up. If the fuses arent blown, and you have all your power, and ground, and still nothing.. Well then in that case the amp is just bad, and regardless of the wattage, you just don't fix a Pyle amp.
Aug 08, 2009 | Kenwood KAC-8152D Car Audio Amplifier
Wont power on after checking all the wires
HI DUDE PLS CHECK UR REMOTE WIRE IN UR PLAYER .... U MIGHT BLOW THE FUSE .. ... THE CONNECTION IN REMOTE WIRE WILL POWER EVEN THE FUSE BLOW ..
Apr 15, 2009 | Performance Teknique ICBM-782 Car Audio...
97 jimmy power seat wont work, blinkers wont work
I have ur aswere for the blinkers. u have to change the breakers under the stereo where the outputs are. there are to gra things
Nov 21, 2008 | 1997 GMC Jimmy
Lowrance LMS-332C GPS Receiver Logo
300 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
