Question about GE APN08AA Portable Air Conditioner
Hot air blows cool for a few minutes then blows warm air
    President:
  • 2,468 Answers
If the evaporator coil on it ices up the thaws then ices up again your low on freon/refrigerant some use R-22 freon and some newer units use R-134a refrigerant,you can look and see if the condenser and evaporator coils need cleaning because if they get dirty and cant get rid of heat and it will build too much head pressure and the compressor will cycle off to protect it,but it sounds like a low refrigerant problem
Posted on May 01, 2010
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Why does the. Air conditioner blow cold air then hot..
which do you want hot or cold . all blowers blow cold air first for a minute or so . then depending on where thetemp dial is set will be either cold cool or warm or HOT .
Mar 13, 2015 | Cars & Trucks
I have a 2002 Ford Taurus, I may have a slight antifreeze leak (strange smell when heat is on), however my heat is very tempermental: it takes forever to heat up the car and when it does, it will only blow...
Check the thermostat. It's almost like a "float" that allows coolant to pass through a hose. If it gets stuck, you have heating issues. Since yours seems to fluctuate, I'd bet it's a thermostat about to go. Fortunately, it's easy to fix and inexpensive.
Nov 29, 2013 | Ford Taurus Cars & Trucks
Air conditioner blows the fuse
SOUNDS LIKE YOU HAVE A SHORT IN THE WIRING BETWEEN THE FUSE AND THE AC PANEL, USE A CONTINUITY TESTER TO CHECK FOR CONTINUITY , IF THAT FAILS OR IS OK THEN CHECK ALL RELATED RELAYS IT MAY JUST BE THAT YOUR AC NEEDS RE GASSING?
Sep 02, 2012 | 1997 Land Rover Discovery
Why would my heater blow out cool air when sitting still and then hot air when going down the road and then it's not all that hot
Try flushing or blowing high pressure air through the heater core lines. its sludge build up and need to be flushed through heater core only. check antifreeze fluid level. only put in straight antifreeze, do not mix. most people do not know what mixture should be, so be safe and add straight, it will not hurt it, i run 100% straight antifreeze and never had a problem or worry about it ever freezing and cracking my block, heads or radiator cracking.
Jan 29, 2012 | 2001 Daewoo Nubira
Air conditioner is blowing slightly warm air and not cooling when it is turned on
If after a few minutes it is still warm to hot air, try recharging the cooling system. Parts stores sell kits with instructions on how to do this.
Aug 28, 2011 | 1992 Honda Accord
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Apr 27, 2009 | Bryant 462AJC021BA Air Conditioner
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Heater blows cold air
With the car warmed up,feel the heater hoses,are they both warm/hot near the firewall in the engine compartment?If they are both warm/hot,then the heater core should have circulation through it and it may be a "blend door" issue in the heater a/c assembly.If they are not warm/hot then the heater core could be dirty and plugged up and needs to be flushed.
If the above does not help,a drain and vacuum of the cooling system and vacuum refill will remove any trapped air.
Sometimes,clamping off the top rad hose and holding the engine rpm at 2000 rpm will force trapped air out of the heater core.(Watch temp gauge when trying this)
Lastly,a NEW thermostat doesn't mean its working correctly.
May 18, 2017 | 2005 Lexus SC300
Intertherm heat pump blows hot then cold then hot
You may have a problem with a temperature safety system.  Before changing anything else, check to see if the unit is clean!!!  Dirt/dust can fool the safety system into an overtemperature status.  Inspect the heat coils for damage and dirt.  Gently clean.
Nov 23, 2008 | Intertherm P3RA-048K Air Conditioner
GE APN08AA Portable Air Conditioner Logo
122 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
