Question about Kingston 4GB Secure Digital High Capacity Memory Card
Mini sd card locked please help yo open - Kingston 4GB Secure Digital High Capacity Memory Card
    Scholar:
  • 65 Answers
You should be able to push it in and have it pop out a little. Gently pull it out. Does this work? If not, please let us know and we'll try to help.
Posted on May 01, 2010
Card locked
If your camera uses a SD memory card then -
SD and Mini SD memory cards SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Feb 02, 2013 | Canon PowerShot SD600 Digital Camera
SD memory card is locked. How do I unlock it?
Jan 20, 2013 | Sony Alpha DSLR-A290L Digital Camera
How to find the file manager in sony ericsson xpera mini e10i
i need to open the memory card folder to view all the things in my memory card ( in the phone itself )
Jan 06, 2012 | Sony Ericsson XPERIA X10 Mini E10i...
Cant format sd card
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then Format It.
Regards
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | JVC GR-D275 Mini DV Digital Camcorder
How do i turn off the write protection on my mini SD card?
On the Mini SD adapter, there is a lock tap you push down usually when you put your mini SD card in to it, then into the USB adapter. To turn off the write protection on your mini SD, simply do not lock your mini SD in its adapter.
If that doesn't work, the write protection sensor in the device reader is not reading the card's lock switch properly. First, try moving the lock switch on the card slightly towards the lock position - this worked for me. Another trick is to put a piece of tape over the lock switch area on the card. It seems the fail-safe position is write protected, unless the switch is closed by the tab on the card in the 'unlocked' position, signaling a writable card.
If these simple tricks don't work, the 'unlocked' sensor in the device reader may not be working; it's likely to be a mechanical switch that my have failed. Some have claimed success performing micro surgery to permanently short the switch in the closed position, essentially removing the write protection. This would require more skills that the average person has. Proceed at your own risk of damaging the device.
Dec 12, 2010 | HP Cell Phones
I got the message "Your Disk is Write Protected" when i go to format. How i format my Transcend disk. Please help me. Thanks.
Removing the write protection depends on the source of the problem.
Broadly speaking, it can be any of the following scenarios
  1. There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  2. There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  3. The mini sd card has some error: Go for a low level formatting.
  4. The card has virus: Remove the virus. The link for the steps is present in the related link at the bottom of the article.
There is an easy way to solve this problem: Simply put the yellow lock in the middle of its slider. No sticky tape required, as shown below. But if your still having the same problem i suggest you try the sticky tape.
problem is only that small moveable yellow lock switch is not making, just put sellotape over it maybe two layers needed to make switch.
== Answer == Even though what is written below may work, the problem is probably that on the card reader (if you have one) there is a small switch that has lock written on the side. If this is pushed down, the drive is write protected, push it in the opposite direction and it may fix your problem I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
Your card should work fine now... don't know why this has to be done, but it works! Additional info:
Reason #1,
the mechanical lock switch accidentally moves to the "locked" position during insertion due to the poor quality of the switch. Hence, by taping it, you are actually preventing the lock switch to travel towards the lock position. i.e. downwards.
Reason #2
If the above fails, it is likely your SD card reader/writer's fault. But don't discard it or buy a new one yet. Allow me to explain the mechanical design of the SD card lock mechanism. So that you may choose to repair it if you want to. You will need a small paper clip and screw-driver to open your card reader. (Don't proceed if your card reader is still under warranty, please return/exchange with manufacturer) There is a mechanical switch very much like a micro push button (I wish I could show you the picture/drawing). Anyway, depending on the position of the lock switch. You either push or release this micro push button inside the SD card reader.
Due to mechanical wear and tear, or some forceful insertion of the SD card, the micro push button is in its "open" circuit position, i.e. write-protected. In order to make the SD card reader writable, we will need to "close" the circuit. (Note: this is an irreversible process as I will be telling you how to remove the write-protection feature of your SD card reader. Once you do this, you would be unable to use the SD card lock switch to lock your data. So, just be careful not to accidentally delete your data)
To proceed, you need to remove the main circuit board from the SD card reader/writer enclosure. The location of the micro push button switch is the same location as the unlock position of the SD card when inserted in the SD card reader/writer. From the BACK of the exposed SD card reader, insert the unfolded paper clip (same way when you try to poke something like a device reset button) except, that it has to be long enough to allow the micro switch to touch together for contact. Then insert the SD card. Once the contact is "closed", your SD card reader/writer can write again. I understand that without a drawing, this may not be very helpful. Please provide suggestions or better explanation if you can. Thanks.
Or, just tape the lock switch to unlocked. This also works for SD cards in normal size. back up all the files u have on ur card then follow these steps
1. Go to Control Panel
2. Go to Administrative tools
3. Go to Computer management
4. From the tree menu on the left select Disk Management
5. Now on the right side you will have a list of all storage devices connected to your computer. Select the one that is your mini SD card. BE CAREFUL WHEN CHOOSING THIS BECAUSE YOU COULD FORMAT YOUR HARDDRIVE. Double check the name in My Computer
6. Right click on the SD card and select format. A new window will pop up showing format options. Select FAT32 from the file system drop down and check the quick format option and then click on OK
7. Enjoy your mini SD card without that annoying write protection
Sep 25, 2010 | Transcend (589307) Media
What should i do if my nokia (3110c) not switching on? It is blinking while i open it.
hi,
lets try to fix your problem without spending a single cents..removed your micro sd ,(small memory card of your phone) then scan it in computer,,by doing this you need an all in one card that supported mini sd,mini sd ,memory stick etc..then you will find if your micro sd is having a virus..back up your files then reformat your micro sd ,then after formatting back your files...without your micro sd open your phone ,if it is ok now ,so the problem is your micro sd...if still there the problem ,reset your phone by doing this ,type *#7370# and enter your locked code..wait until the phone reboot itself...goodluck ,i hope it will help you..
Jun 16, 2010 | Nokia 3110 Cellular Phone
Please tell me what do i need to do to get my SD card unlocked? I uploaded photos to the the computer but card became locked and will not allow me to take more photos.
Hello. There is a tiny sliding lock on the SD card itself. Remove the SD card and look carefully around the perimeter and you will see the tiny lock mechanism. It simply slides between lock and unlock. Joe
please rate my answer as very helpful. Joe
Apr 27, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
How to remove write protection from sd memory card
On the Mini SD adapter, there is a small lock tap button,you push down usually when you put your mini SD card in to it, then into the USB adapter. To turn off the write protection on your mini SD, simply do not lock your mini SD in its adapter.
Mar 20, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Aug 13, 2009 | HP Compaq nc6230 Notebook
Kingston 4GB Secure Digital High Capacity Memory Card Logo
60 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
jairo sanchez
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
