Question about Symbol MC9090-G RFID Handheld Barcode Scanner
Mc9090-g as an AS/400 terminal what is the screen size...meaning lines per screen and characters per line?
    New Friend:
As said above, this can be changed in the configuration of wavetech Win CE 5 Wavelink 9000_AS TelnetCE or Win Mobel 5 Wavelink 90_05_AS TelnetCE But a CTRL A also turn the key board off and on MC9000 download at http://www.wavelink.com/download/downloads.aspx?
Posted on Dec 14, 2009
  • 12 Answers
It's not like your old DOS scan guns where there was a definite number of characters (rows and columns) that could fit on the screen. Instead, it runs Windows Mobile or Windows CE, which has a graphical interface (like your PC). It comes preloaded with terminal software from Wavelink to connect to your AS400, and you can set how large or small you want the font to be in that terminal emulator. So the answer is, the "lines per screen" and "characters per line" can pretty much be as many or as few as you want. It's a trade-off between how much you can fit on the screen and how well you can read it if you were to choose a font size that is too small.
I will say that Wavelink does a good job with this emulator at allowing you to scroll around the screen though. If there is anything that won't fit on the screen, you can just press the Ctrl key and then use the up/down/left/right arrows to page around the screen.
Thanks,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk, push-to-talk for the MC9090)
www.radicomm.com
Posted on May 13, 2009
SOURCE:
How do i change the business name, address and abn on the receipts for a Samsung ER-650
Turn key to "PGM"
Press "7"
From the
LOGO DESC. PROGRAM screen, press "0" to display the PREAMBLE screen:
Using the alpha numeric keyboard overlay, type the first line of the message.
Each line (6 allowed) can be up to 32 characters, although only the last 19 characters you have entered will display. If you make a mistake, press the "BACKSPACE" key to erase the previous character. After you have completed typing the first line, press "ENTER"
to accept the new line and advance to the second line, or press
"ESC"
to return to the LOGO DESC. PROGRAM screen without making any changes.
Thank You
Team
ACP ONLINE
Jan 29, 2015 | Samsung SAM4s ER-650 Cash Register
Ip3500 printing misaligned vertical band
my copier nashuatec 3722 .when start copier give me code E-4
Dec 07, 2013 | Canon PIXMA iP3500 Printer
My writing is so small i can't read any thing on my computer because of this i can't read anthing you write back so can someone call me at 901-283-0239
You can increase the size of text by pressing control + or - buttons press control button first. Also there is zoom in the tools section and also you can increase the size of text in the control panel or the web page under tools sections of most browsers. If we new the browser or what you text is small in or even if it was small every where you can change the resolution size of your Windows. Win 7 you can incease text by going to control panel click on display once there go to where it says increase your text size. Not sure what your operating system is either. So assuming it is Win 7 I hope that this assists you. John
Jan 26, 2011 | Computers & Internet
I want to have the source codes for printing diamond shape asterisk in visual basic
I am pretty sure I got this as a homework assignment in programming class. If I had someone give it to me then I wouldn't be even the limited programmer I am now. That said, I will help, but I will not give you the full out answer.
  1. The number of stars and characters per line are an odd number to make the ASCii look like a diamond. For my example, the maximum number of characters per line is five.
  2. Create a variable called dia_star that will hold the spaces and stars. To figure out the number of spaces that should be put into each star line, use this formula:
number of spaces per star = ( max number of characters per line - number of stars) / 2
dia star = number of lines before star and "*"
print dia star
  1. --*--
  2. -***-
  3. *****
Good Luck,
NOLA Tech
Jan 30, 2010 | Microsoft Visual Basic Enterprise Edition...
Samsung STP-103 Thermal Printer will not print lines correctly
Wow, serial communications still in use. Naturally, both units have to use the exact same protocol N81 for instance, so make certain the sending unit is set to the same, then check the cable to verify that the appropriate pins are connected and or crossed. I believe your symptoms can be caused by using hardware handshake and having pins 6,8,20 (20 only if a 25pin connector) shorted on the printer end. If possible, you can try switching both devices to software handshake.
May 07, 2017 | Samsung BIXOLON® STP-103 Printer
Symbol MC9090-G RFID Handheld Barcode Scanner Logo
1,771 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
