Question about Siemens WDi1640 Front Load Washer / Dryer
My siemens WD1252 doesn't change from wash to rinse
My siemens WD1252 doesn't change from wash to rinse and spin.I have to stop the cycle and switch to the rinse program manually. I have clean the soap dispenser and the pump filter at the front. Any suggestions about what could be wrong. Many thanks
Hallo,
I have the same problem since yesterday. I've seen that probably it doesn't warm up the water. If I change washing temperature to "cold" everything works normally. I think that heater is broken.
Have You resolved your problem? Have You called service?
Best regards.
Bartosz
Posted on Jun 13, 2010
Siemens avantgarde washing machin stopping at rinse stage
Does the washer pump out the water after the wash cycle? If not then check the drain lines coming from the pump to make sure that they are clear. Your pump not pumping will cause the machine to stop working as well
Mar 23, 2014 | Siemens Washing Machines
INDESIT WIB101 WONT SPIN
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
Nov 16, 2013 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
My washer only runs until it's time for the rinse cycle and then it stops completely. It doesn't rinse or spin. What's going on?
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
Washer stopped before spin and rinse cycle.
you nead to bay pas the door switch. orb replace
it.
Nov 17, 2009 | Washing Machines
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
525 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
