Question about ASUS 90-A4C1K1000 Keyboard
What comof keys I have to push to get the @ sin?
    Scholar:
  • 65 Answers
If you are using the US character layout, it should be SHIFT-2. That is, hold down SHIFT and press the number 2.
Good luck. Please let us know if this solves your problem.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Posted on May 01, 2010
Do you enter sin 30 to get answer or 30 sin
Set the angle unit to degrees.
Try sin (30)=, and 30 sin
The correct answer is 0.5
Usually if pressing the sin key display sin( then you should use sin(angle) =.
Jul 15, 2014 | Canon F604 Scientific Calculator
How to use sin function
Depending on calculator, enter angle then press sin key or press sin key then enter angle and press equal sign. Make sure angle units are the ones you want (degrees, radians or gradians.
Apr 12, 2014 | Texas Instruments Office Equipment &...
How to use calculator on how to evaluate trigonometric functions
The FX-115ES is somewhat different to other calculators you might know. The sequence of keys is more like writing up a calculation in a textbook, whereas for "normal" calculators operations are reversed in some places.
For example, with most calculators you would type 30 [sin] to calculate the sine function of 30 degrees, with the 115ES its [sin] 30 [=].
The 115ES has all the standard trigonometric functions:
  • Standard functions (sin, cos, tan), type the [sin], [cos] or [tan] key followed by the argument.
  • Inverse trigonometric (sin?¹, cos?¹, tan?¹), type [SHIFT][sin], [SHIFT][cos] or [SHIFT][tan] followed by the argument.
  • Hyperbolic functions (sinh, cosh, tanh), type [HYP][sin], [HYP][cos], or [HYP][tan] followed by the argument.
  • and finally inverse hyperbolic (sinh?¹, cosh?¹, tanh?¹), its [SHIFT][HYP][sin], [SHIFT][HYP][cos], or [SHIFT][HYP][tan] followed by the argument.
Arguments can be given as numbers with mantissa (2.718), as fractions (use the fraction key below [CALC]) or as degree, minute, second (30°12'45") using the [°'"] key for input. To switch between degrees (1 circle = 360°), radians (1 circle = 2?), or grad (1 circle = 400 gon), use [SHIFT][DRG>].
Jan 06, 2011 | Casio FX-115ES Scientific Calculator
Sin 52 degrees 17 minutes = .791 what buttons do i push to get this answer
For writing sine 52 degrees 17 minutes.
1.press sin key.
2.Enter 52 press the key which is above ENG key which look likes 3 commas.
3.Now enter 17 and press the degrees and minute key above the ENG key.
4.After that press '=' key.You will get the answer as .7910.
Thank you.
Apr 05, 2010 | Casio fx-300ES Calculator
How do you use the sin-1
You would press on the SIN key, "sin(" should come on the display, then enter the value, for example 3.5 or -1 so that the display shows
sin(3,5) or sin(-1) for example.
remember to close the sin with the ) on the end.
sin(-1) = -0.841470985
Feb 16, 2010 | Texas Instruments TI-30XA Calculator
Find csc(-330°) to the nearest hundredth
The cosecant function does not have a specific key on any calculator because it can be easily calculated as the reciprocal of sine.
Thus csc(-330°)=1/sin(-330°)=2
sin(-330°)=sin(360°-330°)=sin(30°)=0.5
csc(-330°)=1/0.5=2
If you do not want to be bothered with these facts, just calculate the sine of -330° and take the reciprocal of the result using the [x^-1] key. For the minus sign before 330, use the change sign key (-). Close the right parenthesis.
[SIN] [(-)] 330 [)] [x^-1]
Jan 21, 2010 | Texas Instruments TI-30 XIIS Calculator
How to use trig function keys on my casio fx-300ES
You have 3 keys for the main trigonometric functions: [SIN], [COS] and [TAN]
To use them correctly you must set the angle unit to the one your problem calls for.
Press [SIFT][MODE] [3:Deg] for degree, [4:Rad] for radian, [5:Grad] for grad. Dependig on angle unit chosen a small D, R, or G appears on the top of the screen.
If you need the inverse trigonometric functions arcsine, arccosine, arctangent, you access them by first pressing the [SHIFT] key
Thus
arcsine [SHIFT][SIN] (sin^-1)
arcosine [SHIFT][COS] (cos^-1)
arctangent [SHIFT][TAN] (tan^-1)
The syntax for the function is
[SIN] # [ ) ] [=]; [SIN] 30 [ ) ] [=] gives 0.5
[COS] # [ ) ] [=] [COS] 19 [ ) ] [=] gives 0.945518576
Note: if the argument of the functions are numbers, the right parenthesis is not necessary. But if the argument is an expression (with various operations) better put the parenthesis to make sure the calculator is performing as one wants it to.
By the way, there are no keys, or key combinations to calculate cotangent, cosecant, and secant, but you can use the definitions:
cotangent (x) = 1/tan(x) Do not confuse it with tan^-1
cosecant(x) = 1/sin(x) Do not confuse it with sin^-1
secant(x) = 1/cos(x) Do not confuse it with cos^-1
Hope it helps.
Oct 30, 2009 | Casio fx-300ES Calculator
When I enter Sin(30)the answer is -.9880316241. This not correct. What should i do?
You have the calculator set up to do radians instead of degrees. I'm not that familiar with the TI-83 but I believe you should look for a key labeled DRG. This stands for Degrees, Radians, and, Grads. Push this key and then use the arrow keys to move from RAD to DEG and hit enter. Now enter Sin(30) and you should get 0.5.
Jun 04, 2009 | Texas Instruments TI-83 Plus Calculator
TI-84 Plus silver edition sin/cos/tan
for function = (sin,cos,tan,sec,cosec,cotan)
arc(function) = function^-1, calculated in the first quadrant for simplicity(0-pi/2) (0-90deg), as all functions repeat circularly
just another method of notation
http://www.mathwords.com/t/tangent_inverse.htm
Jun 19, 2008 | Texas Instruments TI-84 Plus Silver...
Computers & Internet Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
