Question about Smart Modular SV3170A
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the monitor off and on the screen appears again for a second before again going black...any ideas as to what might be happening? No one has yet mentioned that they're screen works for a split second before going black.....HELP!
    President:
  • 1,561 Answers
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
Posted on May 01, 2010
Samsung T240 Problem
try check the cables and connection
Dec 17, 2013 | Samsung SyncMaster T240 Monitor
Is there a new windows 7 driver for the Samsung Syncmaster T240 monitor? The problem I'm having is green flickering, where a green tint intermittantly comes over the monitor.
try reducing the refresh rate of the screen. I Hope the Driver for the moinotor is installed !!
But if it is intermittant..
Then Monitor may be going through normal ageing.
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | Samsung SyncMaster T240 Monitor
Goes to black after one second
lcjj, Is unit black and blank screen? or just black screen? do flashlight test after pc boots-up. Can you see images and icons on desktop screen with aid of flashlight?? How old is the unit? Is unit out of warranty? Have you been to YOUTUBE to check-out DIY video clips on troubleshooting and the low cost DIY repairs being done to CCFL back-lit lcd monitors? Your monitor's problem not new one!! Try some of these web sites: www.ccl-la.com/badcaps.htm and www.lcdrepair.us/files/dell_1800fp_power_supply_installation_instructions.pdf and www.badcaps.net and www.lcdparts.net and www.ccfldirect.com and after you finish with that you can start reading the fixya PROFILES of "buddymc" , "budmrtn" , "12fixlouie" In short... you will do one of these four things. 1. DIY refurbishment. 2. Contract out refurbishment work. 3. Trade in unit for new. 4. Do a cash+old swap out with Samsung if they are doing a "just out of warranty" swap for "premature failed" units. Do your test and research first. Then make decision on what to do. Good luck. 12fixlouie
Jun 07, 2010 | Samsung SyncMaster 2233SW Monitor
A few seconds after i turn my syncmaster 931bw on the screen goes black but if a shine a torch close up to the screen i can see the icons does this mean the bulbs need replacing?
r_mackie923, If screen display was crisp and bright 1 to 2 weeks ago, you should only need to replace the inverter board or troubleshoot down to component level to restore it to normal use. Just follow links you find in the fixya profiles of "budmrtn", "buddymc" and "louie12fix" and other LCD cold-cathode-fluorescent-lamp monitor technicians here on fixya to determine if you will DIY or contract out the work!! Also view some DIY video clips at YOUTUBE to help with your decision. 12fixlouie
May 18, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Monitor will flash the display for a second then go black again.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 12, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung syncmaster 931a... connected to computer
Hi, its unlikely to be the cable. Most likely cause of this is a faulty inverter board. If you are lucky it will only be 1 or 2 blown capacitors which are easily identifiable and replaceable once you have got inside it. it could however, be almost any of the components on the inverter board or even a failed backlight but this will require further testing and a knowledge of LCD monitor workings.
Nov 03, 2009 | Computers & Internet
Samsung syncmaster t240 with thin colored stripes on display
Once you have stripes or lines in the screen then the only solution is to get the screen replaced but that would cost just as much or even more then getting a whole new monitor.
Aug 14, 2009 | Samsung SyncMaster T240 Monitor
Smart Modular SV3170A Logo
525 people viewed this question
Top Smart Modular Computers & Internet Experts
David Payne
David Payne
Are you a Smart Modular Computer and Internet Expert? Answer questions, earn points and help others
