Question about Canon IXUS 80 IS Digital Camera
Lens malfunction The lens will not focus properly on objects and will not retract.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 01, 2010
Testimonial: "some great ideas , similar to what I have considered. I will try them in the order you suggest."
Sx40 hs not focusing for all shots
Hi Brian. First you have to narrow the problem down. Is it your camera or the lens that's producing the problems. Can you try a friends' lens on your camera to see if it still malfunctions? if it does then it's your camera body. Alternatively you could try your lens on a friends' camera to see if he gets the same problem.
Are you using all the focussing points? If you are then this might be the problem because the focus points are spread across the viewfinder and if one of the points sees an object that is nearest to the camera, it will focus on that.
Try usng only the centre focus point and use the focus lock to try and get good focus. Hope this helps.
Nov 02, 2013 | Canon PowerShot SX40 HS Digital Camera 2GB...
The camera will not fire the shutter when I use my 17-85 lens on AUTO FOCUS. It will not let me manually focus as well. what can I do.
1. First of all, make sure the lens is aligned properly and it's not loose in any way. The camera will immediately recognize the problem and will not let you fire the shutter.
2. Allow your lens to auto focus on an object (preferably something that's on your wall). See if it detects the object when you half press the shutter, and once it does press it down all the way.
3. If this is still not the case, the lens itself may be causing the problem. Make sure your camera is compatible with the lens (though most Canon lens are compatible with the EF-S series, it's still wise to check in Canon.com)
Jun 18, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
My cannon power shot SD1300 IS was dropped with the lens extended and now won't turn on or retract. If it is able to extend when turned on it won't focus properly. Is there any way I can fix it? I got it...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
If power is an issue (no electrical function when trying to turn on), then please see this other article.
Now if you do get the camera to turn on and off properly, try taking many pictures of objects at varied distances. With time, this may help the camera to reacquire its focus.
Dec 22, 2010 | Canon PowerShot SD1300 IS IXUS 105...
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
I had the E18 error--lens wouldn't retract and
Focus problems are quite common after a lens error, it sounds like you still have an issue with that lens unit. If you need help, there's a great site taht just specializes in the powershot problems, nothing else at all. Try going to www.camerasandparts.com and you'll see the fix for this for your SD890 camera. I hope that helps, that site is amazing for the powershots and that's where a lot of people go for help with these. Good luck with it.
Feb 21, 2010 | Canon PowerShot SD890 IS Digital Camera
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
Poor focusing konica Minolta Dimage Z6
I have the same problem and the lens won't retract in.
Sep 02, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Lens barrell doesn't retract for zooming out, only for shutting off.
Hello, Sounds like you have a drive motor/gear assembly malfunction,this type of failure is costly to repair.
Best Regards, Russell
Oct 29, 2007 | Kodak EasyShare DX6490 Digital Camera
Zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Canon IXUS 80 IS Digital Camera Logo
241 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
