Question about LG DLE2512W Electric Dryer
LG direct drive washer dryer stuck at 9 min and wont spin
  • LG Master
  • 12,061 Answers
Http://www.retrevo.com/support/LG-DLE2512W-Dryers-manual/id/443bh340/t/2/
us.lge.com/filedown.do?filepath=1000000201&fileName=DLG2524W...
Top, user manual, below service manual.
http://appliancejunk.com/forums/index.php?topic=2946.0
Posted on May 01, 2010
It only wash & don't spin? Then it stops and leak water by the door....
LG Washer & Dryer 7 (WD12331AD)
Its is a direct drive front loader with 7kg capacity for washing and 3.5kg capacity for drying.
when new
thats 7 kg with wet clothes and water
and only 3.5 kg wet clothes to dry
the older it gets the less weight it can wash and dry
worn motor or drum overload if it doesnt want to spin at all
leak at the door . replace the door seal ..is a most common fix
extra info
It has 9 preset settings, 400 - 1200 RPM, 5 temperature settings, digital display and delayed start timer.
Sep 20, 2016 | LG Washing Machines
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
My new lg direct drive washer just quit mid cycle, it wont start back up the code indicated power outage, but it comes on just wont run
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 04, 2010 | LG DLE2512W Electric Dryer
Stuck on 6 min and wont finish the cyrcle.
if its not on sensa dry the timer is bad
Apr 22, 2010 | LG DLE2512W Electric Dryer
Washer functions normally until it is ready for the final spin cycle then it stops with 9 min left. If you select the spin button, it will spin out.
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Dec 03, 2009 | Maytag Neptune Washer
Wont drain or spin
Hi, Most possible causes are:-
1.Make sure the lid is closed. There is a switch inside that completes the connection. Your washer may not spin or agitate if this connection is not completed. Make sure that the speed selector switch is not between speeds. Verify that the washer is not in a soak cycle. You can also reset the water level up or down to make sure that the water level control switch isn't stuck. If you hear a humming sound when the washer is full of water, you may have something stuck in the drain pump.
2.If one of these is not the problem, check the belt. The main drive motor has two distinct functions. The first function is to spin the basket; the second function is to reciprocate your agitator. Inside your washer's transmission is a crank type gear and connecting rods that are used to agitate the washer, with the spinning coming from the washer motor itself. This usually entails some sort of clutch mechanism. Some things to check if your washer is not agitating and/or spinning are:
3.If you notice weak or no agitation, the splines connecting the agitator to the drive shaft may be stripped and need to be replaced.
4.After a lot of use, belts can become worn or damaged. Replace any worn or damaged belts immediately. If you have a broken belt, replace it and check the pulley to make sure it's not seized.
5.Sometimes the drive pulley can wear out and it won't turn the drive belt. Look for wear marks, pits, or uneven spots. It's best to just replace it with a new pulley.
6.Many washers use a reversing motor. Sometimes it will continue to work in one direction even if it won't spin in the other direction. If your washer has a drive motor issue, you probably need to replace the motor with a new one.
7.The lid switch is a safety device that's there to protect you from sticking your hands into a spinning washer. If this switch goes bad, the washer will not work. You will have to replace it. It is inside the main housing for the washer, and located near the door frame.
8.The coupler connects the motor to the transmission. After lengthy use, this plastic and rubber coupler can wear out. If this happens, you need to replace it.
9.Transmission and clutch assemblies can cause agitator and spinning problems They are fairly complex.
Regards, mannu_rakesh
Sep 11, 2009 | LG WFT1071TP Top Load Washer
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
I have an LG front loader, gets stuck on spin cycle at 9 min
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | LG Washing Machines
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Washer wont spin
sounds like the motor or clutch unit could be the problem I would for sure call in the warrente shop to fix it as if its the motor thats expensive!! good luck
Apr 29, 2006 | LG WM-1832C Front Load Washer
LG DLE2512W Electric Dryer Logo
901 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
