Question about Global Go-Kart Ride-On Cars Battery Operated Yellow
Fitting a drive belt to a Manco Dingo Go Kart
Hi. I have an old Manco Dingo model 808-00. Over a number of years I have fitted drive belt Comet part number 203593A. Now I have a brand new belt out of its original Comet packing and for the life of me I can't fit it. It's just too tight. I have bought another and that is also too tight. Now the distance between the clutch and drive wheel can't change so what has happened? Having fitted these belts before I am lost for words or have I just lost the knack? It was never easy. Now I have two very frustrated kids! Please herlp!! Many thanks David Parker. david@headcornparachuteclub.co.uk
  • david48842 May 01, 2010
    Thanks Silverdragon....off to the sweat shop then!! That means yes it was helpful. Thanks again.
  • 12,061 Answers
Http://www.gokartsupply.com/tcbelts.htm
http://www.gokartsupply.com/identify.htm
www.gopowersports.com/Comet/30series.pdf
Have a look at those links above, i am sure they will help you.
These are really tight anyway, just use a pry bar, and rotate as you try to put it on over the edge... it will stretch anyway, on use quite a bit, which is why it's tight. ONLY if you are sure it is the right one, then you'll be OK, if unsure measure the distance between the edges of the drive, driven, and calculate your length, if it is OK, then brute force, and technique must be used...
Posted on May 01, 2010
Ok so what I did for my go cart was put as much of the belt on as you can back medal wheel then try to put it on the front one now It is now all on back and half on front so push your go cart it will work It is what I did
Posted on Aug 01, 2013
What is the belt configeration for a Craftsman 917.254214 ride on mower?
This video shows several belt patterns for various mowers. I am assuming you are wanting the deck belt and not the drive belt. 4 seconds into the video is the standard craftsman 42 inch belt path. The belt at the bottom is put on the engine pulley. Tip from my own experince make sure that the belt is under the belt guides or you will ruin a belt in short order. Your model number is under the seat and is also a scanable barcode. Another tip is to snap a photo of your model numbers. This is handy when you need parts. More accurate and readable than writing it down. Riding Mower Deck Belt Diagram DIY
Jan 12, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Prolectrix usb turntable
Getting drive belts is easy, fitting them is the problem. If it is still attached in any way make a note or a photo of how it is fixed. This will help to putting a new one on. Measure the diameter of the old belt in mm. You will also need to measure the thickness in mm too. Then put these words into Google: "Turntable Belt xx mm" (use the diameter measurement in place of the XX). Then search the results looking for something that is very close to your belt. If you find the belt, try searching again for the fitting of it. Quote the model number of the turntable. The fitting instructions might even be found on this site.
Feb 27, 2014 | Audio Players & Recorders
Dynamo belt instructions
this model is simple ,14mm ring spanner on idles /tensioner with another spanner locked into the back and turn the nut anticlockwise to take the tension ,also on these models is another idler with a nut and 1/4 drive square after fitting the belt then you can adjust the tension a bitwith this one sometimes with anew adjuster tensioner i slacken this first as well when fitting the belt .
Mar 09, 2013 | 2001 Citroen Xsara Picasso
I do not have the tool to remove the plug to drain the oil from a Ranch King riding lawn mower (Briggs and Straton engine). It's about 11 years old. I don't have a model number but the plug has a...
I believe that you are describing a fitting made to accept a 3/8" drive rod. If you have a 3/8" socket set, place an extention on the rachet, then insert the extention into your fitting. That should get it opened.
Best regards, --W/D--
Jun 21, 2011 | Garden
I bought a greyhound 66015 engine for my manco scorpion go kart and can't figure out how to install the throttle cable on the engine
go cart motor shuts off every few minutes for no reason. Motor is new Greyhound 6.5 horse model # 66015 and has plenty of oil and all wiring seems to be in good condition.PLEASE HELP!!!!
Oct 30, 2010 | Pedal Car Go Kart Ride On...
I require a "O" ring for my hose connection into the gun model number RE116K where can I buy them from??
If you have a hose connect that screws onto the trigger gun with a metric fine thread looking fitting then you would need this o-ring set
Oct 24, 2010 | Comet BXD2527 Pressure Washer Pump
Manco cart tecumseh engine runs but has no power
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 14, 2017 | Garden
Fitting a drive belt on a Masport 155/106 ride-on mower?
I am having troubles finding my model number for a 155/106 so I can get parts for it
Dec 14, 2009 | Garden
When driving I heard a belt squealing while the air conditioner was on. I turned off AC and there was a slight bump under hood and then battery light and brake light came on on dash.  When checked...
The Alternator belt. This belt is used to transfer the rotary power from the engine to a number of ancillary units.
In your case it looks as if the belt drives the Air con, Alternator and brake servo unit.
Any good autoparts store should be able to supply the correct type. Note when posting car related questions quote the Model, Trim level, Year, Engine Engine type and Size as manufacturers can fit different belts to the same base model. The same goes when ordering your new belt. For emergency use you can get an adjustable belt. If you are fitting your own belt there is normally a slide mechanisim on one of the ancillary units e.g the alternator the bolts on this unit need to be slackened and the unit pushed twoards the engine. This will allow the new belt to be fitted. Do not be tempted to overtighten as this puts excessive strain on the bearings of the ancillary units.
Oct 04, 2009 | 1995 Nissan Altima
Dingo by manco
The spring goes from the throttle to the tin paddle. I believe its the governor
Jul 11, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Global Go-Kart Ride-On Cars Battery Operated Yellow Logo
1,177 people viewed this question
Top Global Toys Experts
ray gallant
Are you a Global Toy Expert? Answer questions, earn points and help others
