Question about Husqvarna 28cc Gas Line Trimmer
We have a 125cc line trimmer and it starts fine the first time but when it is hot and runs out of petrol it is very, very difficult to start. What can we do????
  • 64 Answers
Clean the carburetor and check the fuel filter.
Posted on May 01, 2010
Just brought new mech choice 25cc petrol line trimmer put petrol with oilmix in ,follwed instructions cant get it to start why,did we miss something out in getting it to start
How did you mix the fuel? Best to make it up in a jerry can. Mix the fuel and oil in the can. It may well be flooded. Try starting with ignition on, choke open and full throttle, might take up to ten pulls.
Sep 26, 2013 | Craftsman 25cc Gas Line Trimmer
Sovereign strimmer HS-PT-2538
I had this problem once when machine was hot it was difficult to restart, I've found putting choke on slightly, about a quarter of the way, and not touching the throttle will see it starting, then put choke back off and leave it to idle for 20 - 30 seconds before using. Seems to be a characteristic of this strimmer.
Jun 11, 2013 | Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
2004 Quest 500--Starts fine. Will run for about 1/2 hour. Starts to sputter and back fire then stops. I remove plug and its black. Change plug and starts and runs as new. Then it repeats itself again....
The problem would appear to either be with the mixture or with the head. Too rich a mixture (too much fuel) will cause black plugs - when you take them out do the engine and plugs smell of petrol? You need to adjust the carburettor. Mark where the throttle screw is to start with and then slowly screw it (in - I think) to reduce the petrol flow.
The other alternative is that their is a problem in the head. Does the engine blow a lot of blue/black smoke out when it is hot. If yes it means a full engine strip down!
Mar 03, 2011 | RTO 125cc Full Size Adult Quad ATV
Ryobi 30cc trimmer won't run. Difficult to start, hard to keep ru
chnge the plug for the best you can get then depending on the mix petrol oil mix u could cahnge that ie if its 50:1 go down to 40:1 or visa versa if that doesnt work bin it and get a sthil or an ehco
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a ford focus 1.8 diesel x reg 1999 girlfreind put petrol in it about 3weeks ago we have drained it all re fueled it and it started and run but now it wount start
poss the fuel filter has petrol in it,replace filter,turn engine over with fuel line unattached to clear lines then fire up,should be fine.you may hve a hot start problem for awhile but fill up with diesel at 1/2 tank to dilute any petrol left.in 32 years in the trade i have put petrol in so many diesel cars,and as long as it starts,keep it running,and start only when cold ish.
Apr 24, 2010 | 2000 Ford Focus
Ryobi Reeleasy line trimmer head PROBLEM
sounds like the clip isn't engaging properly. For a bump and feed they have steps that lock when enough cord is set out. If the head is not locked when its on it will recoil in. Try to make sure its not sitting wrong.
Apr 20, 2017 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Starts easy and idles well with choke on full. Dies in run
Open the air adjustment screw a bit more. There's usually plastic piece that stops you from opening it up. I always break off the plastic.(damn engineers) It's not getting enough gas.
Aug 14, 2009 | Craftsman 25cc Gas Line Trimmer
Hard starting will not restart after warmup
Try this: The next time you run the trimmer, and it begins to die, loosen the gas cap. It should start running again. This means that the gas cap is clogged. Clean the holes out of gas cap, or buy a new one. (If this doesn't help, give a more detailed explanation the next time.)
Jim
Jun 05, 2009 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 28cc Gas Line Trimmer Logo
116 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
