Question about Saeco Royal Cappuccino Espresso Machine
The screen keep showing warming up, rinsing..... and cannot start fucntioning
  • ming_yao May 01, 2010
    my royal cappucino coffee machine keeps appearing warming up, rinsing..... and it didnt start working at all after a long period, an expert advice earlier to examine the motor, but please explain in more detail.
    my royal cappucino coffee machine keeps appearing warming up, rinsing..... and it didnt start working at all after a long period, an expert advice earlier to examine the motor, but please explain in more detail on how i should examine the motor
    President:
  • 2,923 Answers
First, disconnect the Royal Cappuccino Machine from the wall socket. Leave it disconnected to 5 minutes. Plug it back in and it will show "warming up". At this stage, the espresso machine is currently in "standby" mode. Press the "Standby" button to deactivate the energy saving mode.
Then, try to adjust the coffee temperature. Move the asterisk at the end of the line to the menu items.
“Temp. l. coffee”, “Temp. coffee” or
“Temp. s. coffee” and select it by means of the ENT key.
Depending on the selection, the following messages will be displayed:
"TEMP. L. COFFEE "
"MEDIUM "
"TEMP. COFFEE "
"MEDIUM "
"TEMP. S. COFFEE "
You may use the keys ^ or V to select options, then press ENT.
If same problem occur, you need to contact the manufacturer, so that the warranty will not be voided.
Thank you and good luck!
Posted on May 01, 2010
    Genius:
  • 1,040 Answers
Dear Ming Yao,
There is a motor problem. Examine whether your motor is working fine or not...
My Washer stops at the rinse cycle and will not continue. Fast forward to spin and it works. What might the problem be?
Hello, The problem is going to be one of two related problems . All rinse cycles use only cold water and either the cold side of the water inlet valve is not opening and the cold rinse water is not filling the tub and the washer will sit and wait for ever till the tub is full so it can continue the rinse agaitate cycle. If yo do have a warm rinse try that or try filling on the start cycle with cold water wash and see if cold fills,if not the water inlet valve needs to be replaced. I have included a video showing you how to do that.The part number for that valve is 285805 it could be purchased at your local applaince store or online at; searspartsdirect.com apwagner.com appliancepartspros.com repairclinic.com apdepot.com The other potential problem is going to be the filter screen on the back of that valve is blocked and needs to cleaned. To check that turn off the water supply and disconnect the hose,pop out screen and see if its clogged.Also check for water flowing from the hose when disconnected from washer. Good luck,i hope this helps you to fix your washer.
Aug 13, 2011 | Roper RAS6233KQ Top Load Washer
My Pioneer DV-444 DVD player is showing flash sum in the display when powered up and will not even open the drawer. Is there a reset for this issue?
Yes, perform an observation of the device to asertain reset buttons. A reset button would usually have demarkation indication as usable to achieve restore fucntionality of the device. Once locating the reset functionality area, restoration would require a pin like object inserted to reach reset mode knobs enbeded within the device, for safety reasons made to prevent accidental reset. Keep in mind that DVD player device restoration would resestablish to default functionality ever prior user settings acheived. For example, reseting the device repairs only maladjusted settings.
The problem with the device is reopening the clogged disk compartment. However, the reset button is capable of proving restore functionality likely to produce compartment performance as before. Additional details about the devices fucntionalities are acquireable from user manuals. Good luck
Jan 08, 2011 | Televison & Video
The computer keep showing faults and the dealership cannot diagnose any problems. The I-drive screen shorts out taking all of the computer functions with it. Once restarted the I-Drive returns and...
wet ecu board?.....remove the ecu and inspect the circuit board for water/grunge build up acrosss solder points. sounds like the ecu is corroding.... they really should be properly sealed....
Jan 19, 2010 | 2006 BMW 550I
Phone hang up touch screen
pls check your phone memory may be it is full so pls free phone memory.
Dec 11, 2009 | Samsung SGH-E840 Smartphone
Cold water dribbles in rinse cycle, hot and warm water fine
If you check the warm water flow you'll likely find it is HOT...and not warm. Check the faucet end of hose to see if screen is clogged. Should be screened washer with the dome portion of the screen facing out at you. Remove it and clean with brush to remove grit or scale from screen. If you find nothing there you need to replace the water fill valve located at the other end of the hoses. Good Luck
Aug 23, 2009 | Kenmore 22422 Top Load Washer
Cold water wash and rinse not working.
check the screens on the water inlet valve and or replace the valve
May 19, 2009 | Admiral AW22 Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Rinsing...Warming UP... message on Saeco Magic Comfort plus
HI, I am sure you have solved your problem, however:
If you Descale the machine and let it Rinse to complettion of the
cycle; it resets the machine and it will start Rinising after warmup.
Otherwise press the Menu button and go to Energy Saving
then press the Esc buttton. This allows the machine to start
without Rinsing. Also you may turn Rinsing to Off in the Menu.
Nov 04, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco Royal Cappuccino Espresso Machine Logo
104 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
