Blinking light the power light on the front the green light wont stop blinking and the pc wont turn on .
  • fer7560 Nov 23, 2008
    I have the same problem on my Tower SR1120NX. The powerlight blinks and there is no way to switch it on.
    Is this a power supply issue?
    What caused it?
    What can I do about this?
    Thanks
It could very possibly be ur power supply,mine did the same and we changed it out with a spare and it came right on
Posted on Mar 25, 2008
I have a Mitsubishi Model WS-65511 the green light on the front was flahing (would not stop) I replaced the 7 Capacitors as was suggested. The light flashed for a while then stopped and turned green
I think I advised you before (on this page you will find a "make a comment button" which allows follow up questions and answers without posting another question.
Green power light now comes on and goes out in few seconds:
On front of set (not the remote) press and hold when that happens both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a 2 digit code like 2 blinks, 2 blinks, pause and repeat that several times---this is an error code---let me know what code you find.
Note: if you have unplugged the set it clears the error codes and you have to plug back and try to turn set on--let it fail and repeat the self check.
SD TECH
Apr 22, 2012 | Mitsubishi WS-65511 65" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My vaio wont turn on and the green light in the back keeps blinki
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
Apr 28, 2010 | Sony VAIO VGC-RB53 PC Desktop
Wont start power supply binks
What do u mean u unplug the motherboard...?
May 27, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Tv wont turn on
Had the same problem. turned out to be the power supply to the DM assembly. Had to put a power supply, board and a new lamp in. Tech said the lamp blew out the power supply and board. I think it's just a lemon.
Oct 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Computers & Internet Logo
934 people viewed this question
David Payne
David Payne
