Miele hydromatic w701 - doesn't spin or empty on last cycle. Please help, it is old but it needs to kep going for another month!
  • 12 Answers
SOURCE: Miele 418 Washing Machine. Gets to
check the motor brush's.
Posted on Jun 15, 2008
  • 141 Answers
SOURCE: front loader won't balance on spin cycle
The problem may be you might be cloths will be less quantity kindly check the cabinet of the unit and the upper spring is be elongated kindly replace the spring before that check the cabinet any revit has been cutted off
Posted on Dec 25, 2009
SOURCE: Miele W698 Hydromatic washing machine serial no,10/11236327 (purchased 1992)
SREALNO AND MODELS PROBLEM
Posted on May 13, 2010
  • 10 Answers
SOURCE: We have a Miele W701. We just finished a load of
The most common cause for this problem, is the Electro Magnetic Door lock, itself. The part may cost about $170, new. However, you can open the door manually, from the bottom side of the washer. Other causes may be a defective "push button switch," or drainage problem. In a drainage problem, water sitting inside washer, won't allow the user to open washer door, until the water is manually drained out. Good Luck.
Posted on Nov 17, 2010
  • 6277 Answers
SOURCE: require operating instructions in english
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Apr 29, 2011
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
Miele W701 drum stopped working
Hi, I have the same problem as you, same washing machine model, I suspect the problem lies with the electronic control box, the electrolytic capacitors probably dried up from old age and need replacing. The control box is behind the front large door / panel of the machine (not the drum door); in order to open the large door / panel you have to remove the two screws near the detergent drawer, three screws near the entrance of the drum (the three that are covered when the door is closed, and with a screwdriver underneath the machine, right under the wash filter door, there is a release mechanism, push it down to open the door (there are hinges on the other side, so it won't fall off). The control box is the white box held with two screws you can see at 2:23 in the following video I found on YouTube (it's the first video that comes up on Google when you search for Miele W701, in this case it's an Italian model machine, but internally it's the same thing everywhere). Electrolytic capacitors have acid inside and it's perfectly normal for them to dry up over time, lasting twenty years is very good, but all of them dry up sooner or later. The pcb is fairly large and the circuits well spaced and thus it should be fairly doable for anyone with a soldering iron and proper solder (and soldering skills) to replace the electrolytic capacitors with new ones of the same rating (the rating is written on each capacitor). Or you can try to see if you can find a replacement control box from Miele. http://www.youtube.com/watch?v=q3nnSUxQWJI Cheers.
Dec 08, 2012 | Washing Machines
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
It spins, but doesn't pump
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
It doesn't spin or pump
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
The air turbo head for my miele flamenco II S251i spins but doesn't have suction
Check all the filters as well. We have dogs and the hair clogs up the filters. We take a air hose threw our vacuum once a month and it works like new again without replacing anything
Jun 07, 2012 | Miele Vacuums
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Front loader won't balance on spin cycle. thumps and walks almost every time. Spins ok if empty. This is a new problem (last month or so). Machine is less than 2 years old. Maytag model MAH2400AWW...
Dec 24, 2009 | Washing Machines
Washing Machines Logo
356 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
