Question about Claber 8444 Electronic Water Timer
I have just bought a claber 8444 to replace the old one, seems everything nisn fitted properly, selected a program, it says program starts in 10 seconds but nothing happening
Problem with new briggs and straton mower, dust and a lot of it coming out rear discharge area towards motor
Seems you have a rear bag mower. 2 things: first get the proper bag for that model. 2nd- the door panels have seals which do wear out and are replaceable at your local mower shop or you can buy the parts and do it yourself with a few very basic tools.
Jul 02, 2012 | Briggs & Stratton Garden
Can't find tube to fit my back tire - stem doesn't seem to fit properly.
You have not explained in what way the valve does not fit, but this may help: Presta VS Schrader Bike Valves Explained It's very possible that you accidentally punctured the tube when installing it, especially if you used a tool to do so.
I would suggest you get some in-person help - bike shop, bike co-op or friend who's into bikes.
Jul 24, 2017 | Fuji Bicycles Crosstown
Ifit light flashes. Everything works properly except light flashes, which is distracting and irritating.
o 1 Check the connection cablebetween the Pro-Form device and the home stereo, computer, television or VCR ifthe iFit program is not working. Ensure that both the Pro-Form device and thestereo device are both turned on in order to function properly.o 2 Connect the Pro-Form deviceto the computer prior to logging onto the website iFit.com if the iFit programsare not downloading or operating on the computer. The fitness device mustremain plugged into the computer at all times in order to use the iFit programsduring the workout.o 3 Insert the console key andpress the "Program Select" button repeatedly if the iFit program isnot working properly. Ensure that the fitness device is connected to thedesired output device, such as the computer, television, VCR or MP3 player. TheiFit indicator should be lit on the console display.o 4 Press the "Start"button on the console if the time display is flashing on the Pro-Form device console.The iFit program will not function while the time display is flashing.o 5 Listen for a chirping soundif the incline or speed changes suddenly on the fitness device. The chirpingsound indicates that a speed or incline change is about to take place, even ifthe iFit program has not announced the change.
Nov 09, 2011 | Exercise & Fitness
Wii remote will not point and select a program. Remote has been synchronized, seems to be working properly, Board is working and the programs come up on the screen but will not point or let me select a...
Hi. Try to borrow a friend's wiimote that will help you to figure out if it is a sensor bar problem, if it is not a problem with the sensor bar, then it can be the wii software try resetting the console or updating it.
Aug 30, 2011 | Nintendo Wii Fit for Wii
I bought a used 2001 cadillac catera, it only came with one key and since my wife and I drive both drive it we decided to have a duplicate key made. We bought the key and had the key programmed at an...
He's trying to scam you to get out of having to replace a key they programmed incorrectly. The only other possibility is that the ignition switch itself is faulty since that is what sends the signal to the ECM that a proper key is installed. Since it works with the original key that is unlikely.
Apr 18, 2011 | 1998 Cadillac Catera
Makita 8444d second and third gears sound noisy and do not engage
I had the same problem on my 8444, it was out of warranty (just over 2 years old) so I stripped it and found the plastic gear selector ring worn out. Was livid at this as these drills are marketed on the strength of the "all metal" MXT gearbox! Makita UK, to their credit, sent me a replacement gearbox free of charge when I pointed this out to them.
A year on and the replacement gearbox has now started doing the same in 3rd (high) gear. Doubt I can get another free 'box out of Makita (they would probably say I fitted it incorrectly) so am looking at buying just the drill body, which comes out at around £60 and will work with my existing batteries. Just not sure if I would trust the replacement not to fail, but a similarly powerful drill with 2 batteries would cost me wel over £200.
Jul 20, 2010 | Makita 6349DWDE 18V 1/2" MXT Driver -...
The program i use wont fit the screen properly
AMazing charts says you need 1024 x 768. I am looking for a netbook that would have this capability, but the ASUS is 1024 x 600 and that may be the issue.
Jun 15, 2009 | ASUS Eee PC 900 Notebook
HP C4480 will not scan a picture without locking up
If you happen to have the nvidia chip sets I can help you. First thing you want to do is un-install the printer. Use the un-install in the program itself an then go to add remove programs and make sure everything is gone. Then, check on your start menu and in your programs folder. Delete anything you find for hp. Reboot. Go and download the version 10 drivers. The version 11 drivers that come with the printer do not seem to work with nvidia chip sets. I had this same problem. As soon as I installed the older program my printer worked great. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-57266-4&lc=en&dlc=en&cc=us&os=2093&product=3418705
Jan 10, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Network printer not printing properly
Hi Silly,
Try going to the Add/Remove programs and remove the drivers for your printer, then reboot, reinstall then, connect to the network printer, and try again,
Good luck.
Jan 03, 2008 | Computers & Internet
Claber 8444 Electronic Water Timer Logo
29 people viewed this question
Top Claber Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Claber Hardware and Accessory Expert? Answer questions, earn points and help others
