Can you please tell me the part number for the door interlock/switch to Hotpoint WMF 740 Aquarius+ and the cost.
    President:
  • 1,554 Answers
The exact model number of the washer is required for the exact part number of the door interlock but it is most probably part number C00254755. Click this link and click on the list of Hotpoint washers that uses this part. Use the part if your washer is in the list.
Posted on May 01, 2010
HOTPOIT AQUARIUS DOOR LOCK LIGHT FLASHERS
Faulty door interlock easy to fit cost parts about £15
Dec 11, 2014 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint wdl520 aquarius not switching on!
hi if you are getting no power at all and fuse in plug good i would check interlock that is were door locks in next is control panel usually interlock is cause
Jan 01, 2014 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
Im getting error code f-06 what does this mean?
sorry but f-06 is not coming up as an error code for this model, if you can post up the full model number or product number illlook into it again
May 23, 2012 | Hotpoint Washing Machines
Do i have to use some kind of limescale prevention detergent in my wmf 740?
Use a product called "AFFRESH".
You can also use white vinegar.
Pour in one quart and set the cycle to Wash.
Aug 02, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wmf 740 has error code f5 - what does it mean?
I think you mean F05, in which case it means that the pressure switch is jammed on full.
You need to remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well, and look inside the pump.
This should solve your problem.
Nov 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing machine says door problem even though door is shut hotpoint aquarius wmf 740
The door switch is no longer making contact internally or a wire has broken r disconnected. I would verify this with a test meter and replace the switch. Eric
Sep 13, 2009 | Washing Machines
Hotpoint Door Interlock Switch
If it's anything like the WM65 then I did it myself this evening. Be aware that I'm no professional. POWER SAFE? Three screws on the back of the top cover. Top off Remove the soap/fabric softener tray. Four screws off around the gap that's left. Three knobs to pull off (it helps if you remember which way they are set when you do this!) Take the rectangular control panel off, which should now be loose - it has interlocks on the right hand side, so be careful not to break them. You may need to tie or tape the panel safely out of your way to te top of the machine. Three screws off the top off the door section. Open the door unscrew the two short screws holding the lock plate. The interlock switch will fall off the back of the door, held on by it's power supply. Stick your hand round the back and pull it clear. Swap the mechanism (mine cost £14) Reverse procedure. Good luck. This wasn't the fault on my machine in the end. boo hoo!
Jan 02, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
