Question about Toshiba Tecra 8200 Notebook
Laptop monitor problem
I have been using this old laptop exclusively to play video. So I have not used the laptop's monitor for some time.
In order to use the laptop connected to the TV I had to switch video output modes by holding down "fn" & pressing F5 to toggle video modes.
But now, I want to use this laptop again as a laptop, with the laptop's LCD screen. I thought it would be a simple matter of disconnecting from the TV & toggling through the video modes to get the LCD back but that doesn't seem to be working. It was quite a while ago that I connected the 8200 to the TV, so while I can't remember, I'm wondering if I made a change in settings to deactivate the LCD. If I did I can't find it now to re-activate it.
Any help gratefully received,
  • Anonymous Mar 25, 2008
    I am also aware that you sometimes need to wait a few seconds before video mode switching activates.
    Sergeant:
  • 284 Answers
Sounds like the inverter has gone out or backlight of the laptop has gone out.
you would normally see a logo or something when you removed the TV from it, you can boot dual lcd with laptop on and TV. so i doubt something is turned off.
when hitting FN and F5 usually take about 3 sec to refresh the screen. but looks like the LCD screen on the laptop has failed and need to be replaced or the Backlight or Inverter has to be replaced.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Posted on Jul 15, 2008
SOURCE:
How do I attach this monitor to my laptop to use it as a second screen Please?
How do I connect my laptop to an external monitor - Page 2 ...
h30434.www3.hp.com > Laptop & Notebook > Video/Touch
May 6, 2013 - 10 posts
I have a pavillion dv5 2070us and the screen is cracked and I can't see ... I have a pavilion dv6, can someone please tell me the order of the menu ... 06-01-2013 08:19AM ... Once I connected my laptop to the extra monitor, the screen on my extra ...Connect your second monitor while the computer is on. 2.
The HTG Guide to Adding an Extra Monitor to Your Laptop
www.howtogeek.com/.../the-htg-guide-to-adding-an-extra-monitor-to-y...
Aug 7, 2014 - Adding extra screen space to your laptop, however, can be quite a bit trickier. ... If you're looking to do the same, to add a little space to your laptop ...Playing Minecraft on the second monitor was a smooth experience with no drop in FPS. ... Because the AOC does what it does so well, we'll use it to highlight ...
AOC E1649FWU 16-Inch 1366 x 768 16 ms LED LCD Monitor
www.amazon.com/AOC...Monitor/dp/B005SEZR0G
Amazon.com, Inc.
Rating: 3.8 - ‎1,067 reviews
Jan 04, 2016 | AOC 936sw 19" Widescreen Lcd Monitor -...
Can I connect another computer with XP to use the monitor on my K75V
You cannot do this because the video port on the laptop is a video out connection. You need to connect your computer to a monitor or to a TV that has a 15 pin video connection.
Mar 10, 2013 | Computers & Internet
How do I use the split screen on my Dell computer?
The universal way to display a split screen (on laptop screen, and on monitor/projector at the same time) is to hold down the function key (Fn) and press F5. You may have to press F5 a couple times.. by pressing F5 is cycles through a couple different modes (external video only, laptop/external video, and then back to only laptop screen).
Jun 08, 2012 | Computers & Internet
Laptop screen is black
There are a couple of reasons that a laptop screen could blank our. The first is that many laptops have the ability to output video to an external monitor or projector, such as for video presentations. In order to save battery life, there is a function key combination that can be used to blank the laptop screen. Most laptops have these "functions" on the F1-F12 keys in blue and there is an "fn" key that must be used with them to activate the function. Look for a key that has a blue "square" with vertical lines on either side of it. This is the Monitor function key. Press and hole the "fn" key, then press the Monitor function key. See if the screen returns. A corrupted video driver could also be the problem. Do you have any display when booting up? If so, try using the F8 key to get to SAFE Mode. If you have a display there, check and see if there are any problems with the video driver, or just reload the driver. The third possibility is the the LCD's backlighting source may have failed. IF this is the case, you probably have an older laptop and replacement is usually cheaper and more cost effective than repair.
Jan 09, 2012 | Acer Computers & Internet
I have an hp tx 2000 laptop-after playing a game on it last night-i went back later to use it and the screen is black and it will not boot up-even though the blue wi fi lights and fan is running--I hit the...
Turn you laptop off. Connect an external monitor to your laptop. Turn the laptop on and see if you get any video signal on the external monitor (you have to use the right button combination e.g. Fn + one of the Function keys). If you get a signal the problem comes from the screen/backlight/inverter/cable. If there is no signal, check the memory (if you have 2 memory modules use only one at a time, the other one could be defective or check your memory with another laptop or use some known good memory etc.). If the memory is ok then most probably the motherboard is defective (at least the integrated video card). Expensive to fix or to replace it. Have it checked by a professional.
Do you have any warranty on your laptop? See your dealer or HP representative first.
Oct 06, 2009 | HP Pavilion F1703 17" LCD Monitor
My laptop screen is half white half color whats wrong and how do i fix it?
From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I hope this helps answer your ?'s. Good Luck ^_^
Sep 13, 2009 | HP Compaq Presario V6000T Notebook
Problems with Lenovo 3000N200 0769-EAG tv-out
My friend, the easiest and by far the best way I have seen is to set the advance timings on your laptop just right and use a vga to scart cable.
Restart your Laptop to recognize again your TV on the system.
Aug 23, 2009 | Lenovo 3000 N200 Notebook
DVDs do not play on LCD monitor
If you see the dvd on the laptop and not the monitor:
Your problem is probably with your video card and its settings and not the monitor.
Some video cards wont support dvd playback on two screens at once.
What you have to try is to enable only the external monitor and disable the laptop lcd.
This can be done using shortcut keys on the laptop (usually this involves using the Fn key and one of the F# keys at the same time- the F# key may have a picture of two screens on it or be labeled CRT-LCD)
You can also change the settings in the display properties settings.
Sometimes the display settings as far as resolution are set too high for some dvd players. Lowering the resolution can take care of that problem.
Jul 18, 2009 | Xerox XA7-192i 19" LCD Monitor
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Cannot project movies in powerpoint
I have encountered this same problem once in the office when i was trying to do the same thing.
The solution:
*Assuming you have windows xp*
1) make sure the projector and the laptop are connected (FN+F8), do a right click anywhere in your desktop then go to settings by default Monitor 1 would be your Lattitude D620 and Monitor 2 should be your projector, to make sure of that click on the 'identify' it should show a 1 in your laptop and a 2 on the projector
2) now select monitor 2 and select 'use this device as my primary monitor' check mark, by doing this your videos should play in your monitor but they will be a blank/black screen on the laptop (basically we are reverting the order).
Sincerely
McVerick
Apr 20, 2008 | Dell Latitude D620 Notebook
Toshiba Tecra 8200 Notebook Logo
135 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
