Question about PfaFF Hobby 4260
Bobbin trouble Hi,I have just bought a pfaff 1209 and it is seized up with threads behind the bobbin holder, how can I remove it to clear them all out? I have tried with tweezers, but they are in solid,so much the wheel won't turn by hand. I know it isn't the model you have but I think the bobbin cases are all the same. hope you can help. A O'Neill
    Genius:
  • 1,116 Answers
Remove the needle plate for better access and try using a seam ripper to gently cut the threads and continue to remove with the tweezers.
The needle plate is the metal plate under the presser foot and is held into place with at least two screws.
The bobbin fits into the bobbin case.
The bobbin case fits into the bobbin shuttle.
Once you get the jam cleaned away, raise the needle to it's highest position and remove the bobbin case and/or replace the bobbin case.
Jamming can cause the machine to be out of time.
If you thead the machine with the presser foot up, have the bobbin inserted into the bobbin case correctly and the stiching is loose and loopy the machine may need to go into the shop for service.
Posted on May 01, 2010
A thread is caught in the bobbin apparatus. Took bobbin case out and machine is still jammed. Can I take it apart and get the threads out? What to do...
Only thing is to remove the bobbin, bobbin holder if you can, the feed dog cover plate, and then, using a magnifying lamp and a fine pointed pair of tweezers, try and locate the bits of cotton and pull gently out while rotating the hand wheel slowly, rocking it back and forth. Use an air blaster can to blow fluff out, clean, and oil. Including inside the bobbin case.
Feb 26, 2017 | PfaFF Sewing Machines
My pfaff 4.2 keeps saying remove thread jam under the stitch plate. I have cleared everything several times but it keeps coming up on the screen.
Candace, while not familiar with the 4.2, I've had thread jams on my trusty old Pfaff. I hope this helps!
If you are able to totally remove the bobbin cover/stitch plate, please do so. Ideally, there will be one or two screws holding it in place.
remove the bobbin
carefully inspect the bobbin housing; thread likes to hide behind the housing. If you find some thread, use a tweezers to remove it.
If no thread is found, see if there are one or two screws holding the bobbin holder/raceway in place, or just a lever. Try to remove the bobbin holder, carefully noting what the orientation is of all pieces is (using a cellphone to capture pictures of before and after is great!).
Clear any threads from the raceway, carefully re-assemble everything, test and good luck!!!
Apr 22, 2015 | PfaFF Sewing Machines
Remove thread jammed in bobbin case holder
Just open carefully the front of the machine (attention where everything has to be put back), identify the problem and try to remove the thread. Inspect the inside of the machine and the lower bobbin case for thread that may be tangled . Take it easy and you will fix it ; most of the times you we'll not need professional help. Post back to tell us where the problem was and how you fixed it.
Sep 29, 2014 | PfaFF Creative 7570
Needle holder will not move up & down needle, machine is seized.
I would check for thread wrapped around the bobbin holder again. If it is a recurring problem, then there is another problem causing it. Take it back to your servicer and ask them to look deeper for the real issue.
Aug 16, 2014 | PfaFF Tiptronic 2040
Thread caught behind the bobbin case holder
Take off the presser foot
take off the needle plate
take off the bobbin plate
take out the needle,
clip bobbin free,
Examine the bobbin carrier on how it fits into place. (important)
Lift out the bobbin carrier.
Each machine is a little different. You may want to take pictures as you do each step for later reference. Use something like an old egg carton or a muffin tin to keep your parts from rolling around or getting knocked off an lost.
Have fun.
Nov 05, 2012 | Pfaff Creative 4.0 Sewing Machnie
Using a Pfaff Hobbymatic 935. Needle will not move, mechanism around bobbin will not move. Everything is locked in place. Tried cleaning everything, removed the needle (to get the fabric out of the way),...
It is likely the the bobbin holder is jammed up with cloth or thread. Take the bobbin holder out and turn the machine by hand, if it does not move it could have a broken timing belt or slipping coupling.
Apr 13, 2011 | PfaFF Sewing Machines
I have acquired a pfaff 463-34/01 machine and require needles bobbins bobbine holder/s and a handbook Can you help? Regards peterjjohn@tiscali.co.uk Tel 01829 270931
i have bought a pfaff 463 machine and when i sew the thread going through the needle keeps on shreading..... any suggestions
Feb 08, 2010 | PfaFF Sewing Machines
Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Apr 24, 2009 | PfaFF Tiptronic 2030
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Pfaff 1222 Bobbin holder stuck with thread
With power off, take the needle out and the presser foot. Remove the two flathead screws that secure the needle plate from the machine and remove the plate. You'll have a top view of the bobbin housing and see the thread that's stuck to it.
Jan 30, 2009 | PfaFF Tiptronic 2030
Sewing Machines Logo
464 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
