Question about Sony XM-475GSX Car Audio Amplifier
Sony XM-475GSX This amp was working fine for approx. 2 weeks and now it is cutting in and out at all volumes. I used 4 gauge on both ground and positive. Any thoughts?
    Problem Solver:
  • 7 Answers
Try to change your ground location and or try a ground isolater loop
Posted on Mar 26, 2008
SOURCE:
Amplifier causes subwoofer to emit super high pitched sound
YOU NEED NO CHACK THE GROUND CABLE SOMETIMES WITH THE SAME POWER THAT THE AMP NEED START TO BURN THE CABLES AND IF THE GAUGE OF THE CABLE IS NOT THE CORRECT CAUSES THAT PROBLEM TRY TO PUT 2 GROUND CABLES (GREY) IN DIFERENT PLACES AND IT MUST WORK!
Feb 10, 2010 | Sony XM-475GSX Car Audio Amplifier
Can i bridge my sony 1200 watt 2 way amp in to 1 woofer
yes bot if the woofer is 500 watt don't make to loud you will blow the woofer of.
Aug 15, 2009 | Sony XM-475GSX Car Audio Amplifier
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Mar 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp cuts out
Check your ground wire that's more than likely the problem.Try grounding it in a different spot make sure your ground is a paint and dirt free surface also make sure its directly metal to metal.
Nov 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Amp problems
disconnect all power to reset try after 20min
Aug 16, 2007 | Sony XM-475GSX Car Audio Amplifier
Sony XM-475GSX Car Audio Amplifier Logo
110 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
