Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
My FrancisFrancis! coffee machine blows a fuse every time I plug it in. Is this a common problem? Anyone know where I can get it fixed?
3 Suggested Answers
  • 3 Answers
SOURCE: lead
The boiler is brass, and brass is an alloy that contains lead. Grades of brass used in boilers like this are designed not to corrode, and supposedly do not release lead into the water. You probably already have brass fittings on the water pipes in your house anyhow..
Posted on May 09, 2009
  • 1089 Answers
SOURCE: i plug in my starbucks coffee machine and it blows th circuit
Hi
If it is blowing the circuit breaker, you have a reputured heating element.
Posted on Jan 06, 2010
Parts led diode
Sure it's a diode; I think it would be a neon light. If you are able to take the neon light out, I think you will find a similar part in catalogues such as RS or Farnell (maybe Maplin).
Aug 25, 2013 | FrancisFrancis! X1 Espresso Machine
The X1 i have shorts everytime i use it and blows the fuse. didn't use to. do i need to replace the breaker? where can i find replacements?
Hi
The problem is the element in the boiler is blown and the element is shorting to ground. You need to replace the element and it will take care of your blowing the fuse.
Nov 29, 2010 | FrancisFrancis! X1 - Stainless Steel...
Blowing the fuse
I just had this happen to me too... any ideas?
May 29, 2010 | FrancisFrancis! X5 Espresso Machine
How do you open up this machine? I need to get in and do a simple repair--replacing the steam wand. Unfortunately it's so recessed into the case you sommehow have to get the outer shell off to...
The top comes off...you have take the clock out, undo a nut behind it and then you can pry the top off carefully. There are several metal pegs that engage holding clips that you are undoing by prying.
Jan 30, 2010 | FrancisFrancis! X5 Espresso Machine
When machine is turned on the electrical parts blow a fuse. it is not a fuse or voltage problem but water seems to be falling onto electrical parts
if water gets into the electrical parts it will cause it to short out to ground, tripping your breaker/fuse. seal her up and see what happens.
Jan 11, 2010 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis x5 won't steam at all
check small allen screew on steam valve,maybe its just unscreewed
Aug 23, 2009 | FrancisFrancis! X5 Espresso Machine
Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
May 30, 2009 | FrancisFrancis! X1 - Stainless Steel...
Broken Toggle switch
A toggle switch is a common item. Remove the broken one and take it to a hardware store where they will match it up so u will have the new one u need.
Apr 29, 2009 | FrancisFrancis! X1 - Stainless Steel...
Lead
Jan 13, 2009 | FrancisFrancis! X3 Espresso Machine
FrancisFrancisX3 - no power
There are 3 thermostats in the unit- one for the water temperature, one for the steam temperature, and one fuse which blows if the unit overheats. The overtemp fuse is a 'fuseable link' that burns out if the boiler gets too hot (maybe 150C). If that fuse is blown, then you probably have other problems, since the unit won't get that hot unless the steam thermostat fails.
Even if the thermostats have failed, you should get the power light when the unit is plugged in, and the pump should work, but the boiler won't heat up. If you get no power at all, then you have a wiring fault somewhere.
Oct 18, 2008 | FrancisFrancis! X3 Espresso Machine
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
150 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
billconfused
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
