Question about Hannspree XV32 32 in. LCD Television
I have a hannspree lcd 32" t23b HD tv and the screen went black but the sound still working
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, since the Hannspree T23B is an LCD type TV, a simple test is to shine a flashlight at an angle towards the screen when it has blackened. Aim towards the area where the volume level is usually shown. Press on the volume control Up/Down. If semblance of the level could be seen even darkly, then the problem with the Hannspree would be a backlighting issue. Backlight as the term implies, refers to the soft whitish glow provided by small tube like bulbs behind the screen. This then would almost always be a hardware fault, not a setting nor a configuration concern and would require that the T32B be opened up to effect repairs.
Options then are:
  • consider a DIY (do-it-yourself) repair if and only if comfortable working with electronic components & circuitry, use of a DVM/VOM, a soldering iron/station and safe practices with electrically powered devices. Access to a Service Manual or at the very least, a schematic diagram would be a necessity;
  • should you be uncomfortable with a DIY, perhaps your best bet would then be to consult with and/or seek the services of an authorized Service Center (specially if still under some form of extended warranty) or a qualified professional.
If a DIY is being considered, possible suspects are:
  • CCF (cold cathode florescent) lamps (least likely);
  • controller (a possibility);
  • power supply particularly to the inverter (likely);
  • inverters (most likely).
The inverters are responsible for supplying the high frequency high voltage power used by the CCF lamps. Due to heat related issues, capacitors tend to leak and/or bulge which causes them to fail. The same would hold true for the power supply.
Good luck and thank you for asking FixYa.
Posted on May 01, 2010
32" Element HD LCD TV screen often sticks to one
The tv have a long board called a LCD inverter board it is dying.This LCD inverter board help the tv LCD screen panel to have a backlight for the tv LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish a new long LCD inverter board for the replacement.
Oct 09, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Hannspree tv t23b no sound or picture
Check the wires very good on the back if still not working look on you tube for a video on it
Sep 26, 2011 | Televison & Video
Bush TV LCD 32 TV 005 HD
The black screen problem of your TV can be attributed to a backlight driver failure, busted backlight, or LCD driver failure.
The flickering indicates a failing backlight driver or a failing backlight. The screen should be totally black, without any glow, when either of them is not working. To verify, grab a torch and shine it on the screen. You will be able to see a faint display telling you that the backlight is busted or the backlight driver is faulty. If not, the LCD driver or the LCD panel itself is faulty, although it has a low probability due to the symptoms of the problem. The only way to fix the problem is replacement of the faulty part. You may need the service of a qualified technician to determine exactly which one is the root of the problem that needs replacement.
Dec 07, 2009 | Televison & Video
Screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Jun 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Hannspree XV32 32 in. LCD Television Logo
445 people viewed this question
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
