Question about Canon PowerShot A530 Digital Camera
My camera won't let me take a picture as message says Card locked How do i unlock it?/ I have had this camera several years and never happened before.
  • Canon Master
  • 4,738 Answers
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional troubleshooting tips for this problem.
Posted on May 01, 2010
I have had this camera for two years and never had a problem. Now when I switch it on the screen shows the message, " Memory card is write protected" and the camera will not function.
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Feb 05, 2016 | Nikon Coolpix S3300
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
"Card Locked" message comes up periodically and
Switch of the camera and eject the memory card. carefully take a look @ d side of the memory, u'll find a botton with an indication of Lock and Unlock. Move the botton to the Unlock indication.return the memory card back into the camera carefully and dats all.
Oct 10, 2011 | Polaroid i633 Digital Camera
My memory card in my canon camera suddenly won't let me take or delete pictures because it says card locked. - have been using it without a problem but then today it suddenly said "card...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards.If youare getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
Aug 04, 2011 | Cameras
I have a Pentax S12 which I have had for about four years. I have never had a problem and it is an excellent camera.Today I attemted to use it to (take a picture) and on the screen came up 'CARD...
Take out the card and look for the little slide on the side of the card....it is the the "locked" position... move it to "unlocked"
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Jun 14, 2011 | Cameras
"CARD LOCKED"-just downloaded pictures from memory
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
It's easy enough for the switch to get moved accidentally, especially when inserting it into a card reader or a camera.
Nov 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
After I transferred the pictures to my PC, I get a 'CARD LOCKED' message. This has never happened before and I've had my camera for years!!?? It won't let me do anything at all, and I will really...
Hi have you try to removed the mem card out off the camrea and look on the mem card for a small slide button and moved to the unlock position if not its could be the mem card its self or
the mem socket inside off the camera..
hope that will help you
regards Alan..
Oct 13, 2010 | Vivitar ViviCam 4345 Digital Camera
The message said "card locked" so I bought a new memory card after several attempts to fix it. With the new card in, the message now reads, "card unreadable"
Make sure you're using an SD card, 2GB and smaller. The M537 won't work with higher-capacity SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 03, 2010 | HP Photosmart M537 Digital Camera
Card locked
If this happened after the card had been removed then you may have inadvertently slide the card lock into the 'lock' position. If the card has not been disturbed, the very fragile 'switch' may be defective. I would try removing the card and operating the slide-lock several times and then leaving it in the unlocked position.
Jun 18, 2010 | Canon Cameras
Canon PowerShot A530 Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
