Question about Kenwood KDW243A Builtin Dishwasher
Lower spray arm not working, no water or spinning during wash. Any ideas?
  • 630 Answers
Arm is rotated by the water flow. Unplug the dishwasher and check that the pump input is not blocked by food particles etc
Posted on May 01, 2010
  • 1 more comment
  • andyGcon Mar 17, 2011
    I also had the same problem. I checked to ensure that there were no blockages. Once I found that this was not the problem I had to open the machine. I took off the back, top and side covers to access the reticulation pump. On the side of the pump is the solenoid valve that controls the flow of water to the bottom arm. I found that the valve was broken and stuck in the closed position. As i was unable to source a replacement valve I just put it back minus the broken flap (valve). My argument is that since i never use a 1/2 cycle and also have a full dishwasher there is no point at which i would want the bottom arm not to operate. Its working fine now!! Hope this helps
  • howlec Mar 27, 2011
    Hi I have the same problem, which valve is it that stops working? How do I find it?
  • andyGcon Mar 27, 2011
    the valve that controls the water flow to the bottom arm is housed in part of reticulation pump. This sits under the machine directly under the botton arm. What you should try first is removing the bottom arm and pushing something long down the hole to push the valve back into the open position. You will need something no bigger than the diameter of a pencil - make sure its nothing that can get stuck . If this doesnt work then unfortunately you will need to strip the covers of the machine to access the reticulation pump. Get the exploded view of your particular model which shows where everything is located - try the following link for examplehttp://www.buyspares.co.uk/kenwood/dishw...
    Its quite a tight fit to get the valve off but it can be done without taking the pump off by carefully pushing the hoses out of the way as you undo teh 4 screws that hold the valve in place.
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Oct 14, 2015 | Kenmore Dishwashers
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Top spray arm does not turn during wash or turns slightly..it is free of clogs and spins freely by hand
It will spin freely by hand, but needs to spray water out of the jets at the trailing edge of the arm. Check inside the arm for blockage and make sure that water is getting to the upper arm from the pump.
Feb 13, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
The top shelf is not getting clean. There is food residue on the glassware that was not there at the start of the wash.
The most likely answer is that your upper rotor spray arm isn't spinning or spraying water. They aren't powered by a motor - they are driven by water pressure. The most common reason for them not spinning is a blockage somewhere. The lower rotor arm is spraying dirt from the plates in the lower rack onto the glassware and there is no spray from the upper rotor arm to rinse it off.
Check the small spray holes on the top of the upper rotor arm. If they are blocked, use a large pin or a cocktail stick to clean them out. If they aren't blocked, check to see whether the upper rotor arm is spinning by following these steps:
1. Note the exact position of the upper spray arm or spin it so that it is running precisely left to right or front to back
2. Close the door
3. Start any wash cycle
4 After it has finished filling with water and starting cycling the water, open the door and note the position of the upper spray arm again.
If the spray arm is in the exact same position as when you closed the door it's almost definite that it's not spinning. In this event, cancel the wash and do the above test one more time just to eliminate the element of pure chance.
Try the above tests and checks and then post back with the results if you need any further assistance. If posting back, please include the full model number of your Frigidaire dishwasher
Regards,
BElectric.
Dec 14, 2010 | Frigidaire Professional Series 24 in....
The bottom washer arm does not turn or squirt water
Hi Matt.
The lower housing underneath the lower wash arm may still have something blocking the water passages.
If the spray arm is clean and it freely rotates try lightly pressing down on the wash arm and then rotate it. Your checking to see that when water is applied to the spray arm it forces the arm down against the lower housing tower and hopefully does not lock up. If it does lock up while pressing down and rotating obviously you need to find out what the cause is.
You may have to remove the lower wash arm housing and clear the debris from the water passages. Once the passages are clear it should work fine.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Viking DFUD042 Built-in Dishwasher
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Lower spray arm
New Spray arm split around center joint so when it gets hot it opens up spraying water under door
take it back for another
Alan
Oct 13, 2007 | Hotpoint 23 in. BF50 Built-in Dishwasher
Lower arm spinning slow/intermittent
running with the door open indicates another fault that could be dangerous unless you have bridged the catch for testing only, water should flow fast and forceful at all times that it circulates, through both spray arms at once, you have to look for blockages in the system, is the waste outlet pipe high enough, this allows the machine to fill adequately so it doesn't pump intermittently, i doubt very much this is an electrical problem hope i have helped a little
Sep 25, 2007 | Zanussi ZT485 Built-in Dishwasher
Kenwood KDW243A Builtin Dishwasher Logo
604 people viewed this question
Top Kenwood Dishwashers Experts
Oloyede Monsuru
ashburton
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
