Question about LG KU990 Viewty
When i connect my usb and phone to the laptop the sign dosent coe
When i connect my usb and phone to the laptop the acess sign dosent come up can you tell me why and how to fix it
  • 1,555 Answers
There can be following 3 problems.
1. USB driver on your laptop. If the driver on your laptop is not installed then it won't work. Confirm by putting any other usb peripheral.
2. USB cable is U/S. try change it.
3. Communication port on your mobile is U/S try to attach another mobile through same cable and check. If faulty then you have to replace the connector.
Posted on May 01, 2010
My laptop omlet to conect a phone charger dosent work enymore
Good Day!
maybe you just accidentally disable the usb port, so that you cant able to char your phone.
Mar 04, 2013 | IBM ThinkPad T40 2373 Notebook
Connection with PC by USB
Be sure the USB cord being used is not just a charging cord(it will have the "trident" picture on it if it is for data transfer)
Oct 07, 2012 | Android Galaxy Ace
500 GB Transcend HD.
how long was it the water for was it fully submerged ?
it might water damaged beyond repair
leave it in a very warm to hot place for a few hrs to dry out any moisture inside it
hope this helps
Jun 20, 2012 | Transcend 2.5 StoreJet Portable Shockproof...
Drive no longer powers up
easiest thing to try is a new usb cable could be that simple. try that and let me know the results
May 20, 2012 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Didnt get a disc with my samsung galaxy cant connect it to the laptop dosent reckonise the device
You don't need a disc, you need Samsung Kies (so just google for it and download it to your computer). After installing you will have a working driver for your device. Under connection settings and I mean USB connection settings (you can find it in under Settings -> Wireless and network, change it to connect to samsung kies. Connect the phone and open Kies and everything should work.
Jul 29, 2011 | Samsung Galaxy S GTI9000 Smartphone
How to ACESS INERNET TO LAPTOP THROUGHT MOBILE
First of all you will need to have settings save to your phone sent to you by your phone provider. If your phone can access the web, then that means your phone already have the settings for surfing the net.
Secondly, you will need pc suit software or any other mobile suit software compatible for your phone. Install the software to your pc..
Third, you must specify the mode of connection that you want for your phone and pc.. If you will be connecting your phone to your pc via blutooth... then you will need blutooth device installed and connected to your cpu.... If you will be connecting via usb data cable.. then you will need driver installed for your data cable.
Fourth, on control menu.. double click Phone and Modem.. Install your phone as your modem.
Lastly, If all is done.. run your pc suit... pair your phone to your computer.. Access dial up via phone modem... and there you go.. just make sure your phone is loaded so the connection wont stop..
Good luck.
Much appreciated if you rate this help. thanks.
May 21, 2010 | Computers & Internet
I do not know how to use it
It has to have gprs and it must be modem enabled
3.You need a means of connection from your cell phone to your computer or laptop (inferred,bluetooth or usb cable)
4.You need a dialup connection
5.You need to know and change your proxey settings
Step 1:Take your gprs enabled cell phone and connect it to your computer or laptop using either buletooth,infered or a usb cable, date card
Step 2:Create a dial up connection.Go into yor control panel,then into internet options.Then go to connections and add.Create a dial up connection and when it asks for a phone number type in *99#
Step 3:On your new dialup connection add the same proxy address you have on your gprs in your cell phone.
Step 4:Now on your cpanel there should be something called modem options (If your 's doesn't have you'll have to search your computer for an option that allows you to change the acess point name or also known as the APN) here you must change the APN to whatever your APN is on yor gprs in your phone.
Step 5:Go to start menu and connect,then connect to your dial up (make sure your cell phone is connected to your computer or laptop)
Step 6:Start your browser (internet exploxer,opera etc) and start surfing the net.
Note that every cell phone has it's own speed for example 3g phones can reach up to speed's of 48 kb/s.
I've tried to make this tutorial as simple and as easy to follow as possible.
Jul 14, 2009 | Cell Phones
Sony
hi there 46-79 , you dont say how you are trying to connect the Sony W810i , are you using USB cable or bluetooth to try and connect the W810i ? if your using bluetooth you will need to purchase a bluetooth dongle for the laptop so it can communicate with your mobile.
                        If you are using a usb cable to connect the laptop to your Sony W810i make sure you are using the proper type of usb cable , some usb cables are not suitable for connecting mobiles to a PC or a laptop.visit sony ericcsons website and sign up for free to find out the comaptible types of usb cable for your mobile...
Aug 27, 2008 | Sony Ericsson Walkman W810i Cellular Phone
HUMM in phone line(modem)
turn off the mic or the extrernal speaker if this dosent work there might be a problem with the phone cord or your house wires
Dec 25, 2007 | HP Pavilion dv1000 Notebook
LG KU990 Viewty Logo
70 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
