Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wmf 740 stops and flashing DOOR message flashing. Ples what do i do?
    President:
  • 1,554 Answers
The door switch might be loose causing the control to alert the user that the door is open or not properly closed. Close the door properly and hold it firmly closed and see if the message stops flashing. The door switch might need be replaced.
Posted on May 01, 2010
  • Jahn27
    Jahn27 May 01, 2010
    Feel free to update us and specify the exact model number of the washer if you need the part number for the door interlock/switch.
    It's a pleasure to help you and thanks for using Fixya.
I have got code F- 05
Irene,
F-05 is a drainage problem
check your filter, take a quick look at the attached video
Aug 22, 2016 | Hotpoint Washing Machines
Hotpoint aquarius 7kg wmf 760 washing machine door wont open
the pump filter is blocked you need to pull the washer out and tilt back the door should open but there will be water in it unblock the filter should be ok
Nov 29, 2012 | Hotpoint Washing Machines
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
Im getting error code f-06 what does this mean?
sorry but f-06 is not coming up as an error code for this model, if you can post up the full model number or product number illlook into it again
May 23, 2012 | Hotpoint Washing Machines
Do i have to use some kind of limescale prevention detergent in my wmf 740?
Use a product called "AFFRESH".
You can also use white vinegar.
Pour in one quart and set the cycle to Wash.
Aug 02, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wmf 740 has error code f5 - what does it mean?
I think you mean F05, in which case it means that the pressure switch is jammed on full.
You need to remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well, and look inside the pump.
This should solve your problem.
Nov 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing machine says door problem even though door is shut hotpoint aquarius wmf 740
The door switch is no longer making contact internally or a wire has broken r disconnected. I would verify this with a test meter and replace the switch. Eric
Sep 13, 2009 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
227 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
