Question about Indesit 24 in. D63 Free-standing Dishwasher
Switch it on, light buzzing sound, feels loke motor is not workin
Green lights are on, does not look like it can pump water in, no usual powerful sound of washing
  • Indesit Master
  • 19,396 Answers
Hi.
Try tripping the circuit breaker or disconnecting power cord for a couple of minutes. While power is off, check the inlet cable at the back of the machine.
If there is no water getting into the machine, and there is humming sound when the machine is supposed to cycle, test inlet valve, pressure switch, and finally electronic control.
The electronic control is replaced only when inlet valve and pressure switch are surely working, as this are more common faults.
If inlet valve is dual, it can be tested swapping hot and cold. Otherwise it is tested reading impedance at valve solenoid contacts.
The pressure switch is tested jumping its contacts and cycling, take care to prevent overfilling, as the switch will not work while contacts are jumped.
If everything is Ok, then a tech will need to read volts at the electronic control board contacts.
Disconnect power before performing any testing or maintenance operation on the appliance.
All tests must be done by a trained technician.
To get a technician on site , or to get a quote on repair ring the number listed on the owners manual.You can also get an US technician contact using our directory:Contacts.
To get parts ring the manufacturer at the number listed on manual.
You can also use one of the websites listed here to get parts and diagrams:
Where do I find parts and diagrams for my Appliance?
Regards.
Posted on May 01, 2010
  • 630 Answers
Check the water supply. Sounds like the solenoid has operated but water not flowing.
Indesit Dishwasher LS12-E2100. Lights work in door and there is a buzzing noise when the door is shut, but it won't fill with water, so it will not work.
Generic step 1: Clean the internal filter.
There are manuals and troubleshooting guides online. Go find them.
The buzzing noise may be a symptom of the problem. If the main motor cannot turn, it will stall and buzz. With the power disconnected and the unit pulled out, try to turn the main pump motor from the bottom (They are invariably in the center of the
unit on the bottom of the wash tub). If that turns freely, something else is buzzing which may or may not be a problem. Try to find out what is making the noise. Note: If you cycle the unit with it pulled out, it will be obvious if the motor can turn or not.
An old mechanics trick (Old trick, not mechanic): With the unit pulled out, and exhibiting the problem: Take a 1/4" wooden dowel (do not use metal!!) and press it against the little flap of your ear so as to cover your ear canal. Do not insert the dowel into your ear! The dowel will mechanically conduct sound to your ear. Now, with the dowel on your ear, probe around the bottom of the unit, listening to find the loudest buzz. You will quickly get the hang of it.
When you have found what is buzzing, you may have found your problem. You may not recognize whatever you find is buzzing. Consult the online documentation.
The buzzing may be the water inlet valve. It may be the pump motor that has ingested something that keeps the motor from turning. It may be something else.
I am guessing that the buzzing is not good, but it could be benign. When you have found the buzz, consult the manuals & troubleshooting for further instruction.
I have the feeling that this problem will ultimately be resolved by a service tech., but good luck anyway
Pete
Jan 30, 2015 | Indesit Dishwashers
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
My Lasco whirlpools tub is getting power and the air switch is working. When i fill the tub and turn it on i hear a buzzing sound from the motor but it does not pump the water. I thought maybe the pump is...
The first step is to gain access to the pump, bring a flashlight and see if the pump motor is moving by looking for some rotating part.
At the same time, ensure that it is the motor that is buzzing.
Post again with this information.
Gary
Feb 11, 2011 | Home
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Water not pumping into coffee maker
Sounds like a bad pump...I would contact Keurig Customer Service if your machine is still under warranty -- they will probably send a replacement.
Apr 15, 2010 | Keurig Elite B40 Coffee Maker
Turn signal does not work and buzzes. Is it a
check the relay that sends the power to your lights, its probabbly giving u that problem...if its workin properly check the light switch
all of this apply if u checked the fuses firts and u found no problem there
Nov 13, 2009 | 2001 Nissan Altima
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
MIele waterproof system reacted
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
Operating instructions for Washing machine W 3923 WPS
Nov 16, 2008 | Washing Machines
Its gone off!
The green light indicates the unit thinks it is out of water. Take of rewervoir; make sure the inlets are not plugged. Open the little plug on side, clean tank w/ clear water only, and shake out all water completely. Put it all back together, but leave reservoir off. Turn on and run unit "dry". Your should hear a "flutter" sound as the unit trys to pump water from missing reservoir, the heater/steamer should be sizzling hot & pressurizing. THEN the green light if ome ON, asking you to switch it off, refill & install the water reservoir. If things don't happen in that sequence, you should be able to determine what is wrong.
Dec 27, 2007 | Rowenta Perfect Iron
Indesit 24 in. D63 Free-standing Dishwasher Logo
152 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
