Flashing standby light - Televison & Video
Tv not coming on is on flashing standby red light
How many times do the standby light flashes at a time? Count this. These flashes are fault indications. Check this to know more about blinking codes to Panasonic LCD and Plasma displays.
Jan 03, 2013 | Televison & Video
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony KV-34xbr800 standby light flahes all the
Flashing standby light is an error code that is specific, there would be pause of 3 seconds in flashing, so count pause to pause and let me know that how many times red standby light is blinking to diagnose problem.
Thanks.
Jan 11, 2010 | Sony Televison & Video
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
560 people viewed this question
Top Televison & Video Experts
Electro Med Services...
