Question about Dometic Refrigerators
I cannot get power in my ref. is there any reset botton or fuse some where?
  • 2 more comments
  • samcorpuz947 May 01, 2010
    I have a Dometic RM2214 refrigerator. It is a three way ref. 12V, 120V and Propane Gas. My Camper trailer is an older model of 1985 Alumalite Holiday Rambler (good shape)
    My ref just quit working. Power cannot get in.both 12V and 120V. Gas is full. Is there any reset botton some where? What should I check first.
  • samcorpuz947 May 02, 2010
    I tried that but there is no fuse capsule any where. I even open the logical board at the bottom of the frige.
    I checked the 120 V yesterday and there is, but I did not check the 12 V. I found out too in my
    12V fuse box that there is a broken fuse, however I am not sure if that is the problem. I replaced it but it got burned right up. So my next work is to find where that short is coming from. I regreted the manufacturer did not identify each fuse electrical line is for in that fuse box..
    I also filled up my propane tank just to make sure ther is a propane ready. Dont worry I will, and I am aware and careful not to have any electrical spark around any Gas.
    Please keep me posted until I found the solution. I really appreciate your back up. I will start working on it again after my Religious meeting
    thanks
    Sam
  • samcorpuz947 May 03, 2010
    Hi, I appreciated your help. First of all, my refrigerator is an RV Ref. Dometic RM 2214. it is a three way ref. 120V, 12V and Propane. in a Holiday Rambler Alumalite trailer. I am positive their exsist both 120V and 12V and Propane gas. I checked them all with my volt meter. I am positive there is a current flow from the breaker box of 120V and the 12V fuse box. The problem is from the mother board or logical board there is no current coming out.
    To operate is to turn the main switch to On position. next to turn the temperature control to #4. after doing that the indicator light should turn green, meaning the function is normal then the frig will work.
    It does not work right now. I took the logical board out completely. I did not see any fuse capsule when I remove it nor any fuse that I can see. also the logical board is very clean. no sign of burned out circuit parts on the outside.
    Thanks
    Sam
  • 713 Answers
Hi,i think you should plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the circuit breakers.If the problem in not from there,definitely the problem is from the fuse,
Remove the plate that covers the bottom part behind your refrigerator,you will find the fuse on the mother board,you have to remove it and solder in another replacement fuse,problem solved.
Thanks and take care
Posted on May 03, 2010
  • Oyelade Gbenga May 03, 2010
    Hi,from all said and done,the problem is possibly from the logical board,it needs to be replaced,i'm positive that after the replacement of the board,power will be restored back to your unit.
    President:
  • 1,554 Answers
Make sure the circuit breaker where the refrigerator is connected has not tripped. Have the refrigerator checked for any possible short circuit if the circuit breaker indeed tripped. Indicate the make and exact model number of the refrigerator for more specific and accurate advice.
Posted on May 02, 2010
  • Jahn27
    Jahn27 May 02, 2010
    The best way to find the problem is by tracing the continuity of the 120 VAC and 12 VDC lines going to the control board using a volt-ohmmeter. Make sure 120 VAC and 12 VDC are present in the respective connections on the board.
    President:
  • 4,070 Answers
Hi! Please try this. Look at the back of the ref. There usually a capsule like plastic which you can find the fuse inside. OPen it and replace the fuse. HOpe this helps and have a good one!
Posted on May 01, 2010
  • dj_relly999
    dj_relly999 May 02, 2010
    Alrighty, good luck!!!
RICOH AFICIO SP 4210N SERVICE MODE SC 545 Power Off On How Solve it this error?
SC545 fusing lamp remains on. reset fuser error in service mode. If it still reoccurs. Possible bad thermistor or power supply board. To go to service mode press up and down botton for about 5 sec and then press enter. In service mode engine fuser reset SP5810 execute
Sep 30, 2017 | Ricoh Office Equipment & Supplies
Forgot parren to unlock tablet
You need to factory reset! from off, press power and volume+ buttons together until reset screen comes up, then move using volume and select using power buttons!
Jan 01, 2015 | ZEEPAD 7 inch Android 2.2 Tablet
Hi, I have a problem with incoming calls: I can phone but I can't receive calling form others...the phone doesn't ring, while the calling phone is ringing as normal. Resetting the phone can help me? How...
format the set.press *3 and call botton.by press those bottons switch on the power botton.dnt release the power botton unless u find formating on the screen.see that the battery is fully charged.ater completing the formating the phone restsarts
Apr 17, 2011 | Nokia 6600i Slide Cell Phone
Give me nokia 5800 master code
I was also looking for that, but i couldn't find it. But i got one solution to format Nokia 5800 it doesn't work for security code.
To format or hard reset nokia 5800 press 'green key, red key and camera botton. After pressing these three botton, press the power which is located at the top. When it shake release only the power botton not the green, red and camera botton. It will start up your phone and after sometime it will display country botton and now you can release the keys. Thats it. This is call Hard Reset.
Jul 22, 2010 | Nokia 5800 XpressMusic Smartphone
Ricoh aficio 3045 error code sc 541
Here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad thermistor,bad fusing lamp or a bad connector.
Oct 02, 2009 | Ricoh Office Equipment & Supplies
How do you reset the change oil light?
Pull the fuse panel door of on the driver's side. Turn car off. While key is in the ON position, press the red reset botton
When tha Change Oil light starts to flash, press and hold the reset botton again. Reset is complete when you hear chimes
Jul 16, 2009 | 2003 Oldsmobile Alero
Service code sc546 what do we need to do to fix this problem?
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Siemens Sx66 Pda phone- not responding for hard reset-
Hello, Did my solution fix your SX66 problem?
Jun 23, 2008 | Siemens SX66
Need microwave reset button
What if you have a problem with the door? and the power won't come back on? My microwave has a safety latch on the door that won't let the power be on when the door is open. I tried to force the door shut accidentally (barely) and now it won't power back on? any ideas? Post Solution
May 10, 2008 | Microwave Ovens
Refrigerators Logo
146 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
