Question about Dell 924 All-in-One InkJet Printer
I cannot print. Give message saying to check all
I cannot print. Give message saying to check all connections, check firewall, turn off/on. Still can't figure this out.
All inter conections show pass. When trying update firmware or Net Flix says cannot connect.
1) try checking your firewall for restrictions, because some firewall that came with you anti-virus ( if you have one) will definitely block those program to be downloaded.
2) try clearing your history and cookies.
if this will not work just send me a message so that i can give some more solution.
Apr 09, 2011 | Panasonic Computers & Internet
Keep getting the error message "Printer not responding".
How are you connecting the printer to the computer? (USB, parallel, ethernet) Make sure there are no error messages/lights blinking and that the unit is on.
If you are using an USB cable, try a new cable. Also try a direct connection if you have a USB hub or print server in use. Make sure the USB ports are active (not disabled for power saving or security). Test the port with a known working device.
If you are using the parallel cable, make sure it is properly secured. Also try a new cable. Again try a direct connection instead of a print server.
If you are using an ethernet connection, again try a new cable. Check if your firewall is blocking communication with the printer. (Test this by temporarily turning off the firewall. If it starts working, make the printer a trusted part of the network. With some firewalls, you may need to unblock communication for both incoming and outgoing communication with the printer.)
I hope this helps.
Oct 18, 2010 | Konica Minolta Magicolor 5450 Printer
Stepson has a 2600 and when installed says everything is ready. when you print, message comes up about a communication problem. gives solutions about what to try, tried them all, except don't know how to...
I don't think you have connected the printer as a network printer. If you have just connected the printer to the computer, the firewall will not block anything to the printer. If it says system doesn't meet min. requirements, try increasing the RAM of the computer. That will probably help!
Jul 21, 2009 | Lexmark X2690 All-In-One InkJet Printer
I can not print
I had a similar problem that was caused by my firewall. I was able to get it to print fine but could not get it to scan.
To test, try temporarily disabling your firewall. Bringing up SX Virtual Link then search for devices. If you can find your Canon, that's the key. Silex has instructions on how to get around some of the firewalls on their web site. I had to figure out how to get around AVGs firewall on my own. Check out silexamerica.com.
Reply to this message if it doesn't work or if you need instructions for the firewall problem.
Good luck helena!
- Susan
May 03, 2009 | Canon Silex Pricom C-6200U (0297V462)...
I cant receive or send Emails. Every thing works
You click "SEND" not "PRINT" to send an email.
Do you have a printer connected?
Apr 25, 2009 | Lexmark Computers & Internet
Computer not recognizing print server
If you connect your printer directly to your computer, were you able to print? Make sure that there is no firewall enabled in your computer (Double check windows firewall or any personal firewall, that could have been enabled).
Jul 12, 2008 | Linksys PrintServer for USB with 4 port...
It just won't print!
try to make un-install drivers for the printer, then reboot and install driver agin.
I think, it might be your driver currepted and cause this problem.
Please post your feed-back.
Gud-luck
Iqbal
Apr 15, 2008 | Lexmark X3480 All-In-One Printer
Error 714 on DX-2000
First off can you ping the printer?
Then make sure in your network settings you set the printer for a manual or static IP address so it is not changing on you.
Try turning off any firewalls you have on your computer or network. On a firewall, you can ping the printer but it will not sent print data. You can write the IP address through the firewall to allow printing.
Log onto your web browser and type in the IP with the firewall on and see if you can see the printer. Then shut off all firewalls and do the same thing.
Also see if the printer has an IP filter enabled, that will stop it from printing also.
Mar 04, 2008 | Panasonic DX-2000 Plain Paper Laser Fax
My printer is "offline"
Try disabling the firewall, printing, re-enabling the firewall. My printer keeps working after re-enabling the firewall (at least for a while). Not ideal, but beats reinstalling the printer.
Mar 01, 2008 | Brother MultiFunction Center MFC-440CN...
Dell 924 All-in-One InkJet Printer Logo
52 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
