Pump not working - Washing Machines
  • 12,061 Answers
Washing Machine FAQ
Washing Machine Repair Manual FREE online - DO-IT-YOURSELF
Washing-Machine-Troubleshooting
OK, those DIY links will help you Also get a service manual for your exact make and model.
Posted on May 01, 2010
My windshield washer pump does not work ,pumps are working ,and still they do not work,is the fuse # 6 ?, what else could it be
your question is confusing. you say the pump does not work then you say the pumps are working. If the pumps are working then check the washer hose for being plugged as well as the spray nozzles.
Oct 27, 2015 | 2004 Chrysler Pacifica AWD
Is there different fuses for the front and rear.window wash pumps
check to see if you have power to pump with a 12v tester,if so, it may be the connection to the pump gone bad .you can always put the test light on the fuse end and have someone make the pump work to see if that fuse controls both pumps. make sure 12v tester is ground well .Also you may want to take the hose off the end of the pump that goes to the line to the windshield and see if water comes out the pump
Aug 06, 2014 | 2002 Dodge Grand Caravan
Pump not working
need more info does system have power to pump motor? if not check breaker if voltage from breaker check switch if you do have power to the pump motor sounds like bad pump motor
Feb 12, 2014 | Zodiac Pool Systems Pool & Spa
No pressure out of the pump
Check for voltage at pump wires is it 115 or 230. Pump works when motor spins. try to prime pump if motor working
Oct 10, 2012 | Plumbing
The pump is on a timer and last night during a storm the pump stopped working?
Try connecting the pump to the mains and bypassing the timer.
If the pump works then the timer is faulty and needs to be replaced.
If the pump does not work then the pump motor is faulty,
Jul 20, 2012 | Pentair Pool & Spa
My 912-005 sump pump will not kick on. when plugged in it hums like it wants to work. We tool the cover off as i expected top see a float but we cant see it. Have never dealt with a pump before. ...
When a pump hums instead of working, there are two possible things.
1) Something stuck inside pump impeller. See if there is rust or debris. Move the impeller and see if it rotates freely. Unplug electrical device before working on it.
2) The pump winding has gone bad and pump will never work again.
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on pump or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 01, 2011 | Zoeller E140 Iron Nonautomatic ...
Pump and filter work fine. After shut down, pump
check for leak on intake union or pump top seal if ok bad seals in pump replace
May 23, 2010 | Sta Rite Pool & Spa
Filter pump will not work
take a pliers and turn shaft with pump off if it turns, turn pump on they tend to stick from not being used
Jun 08, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Yamaha 1987 FZX 750 fuel pump problem. I have new fuel pump and fuel pump relay but the pump is still not working. The pump worked for a short while but then it stopped before even all carburators were...
Most pumps like this work on pressure drop. When the floats open the pump loses resistance pressure and resumes pumping until it feels pressure again.
May 19, 2009 | 1987 Yamaha FZX 750
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
