Question about Baumatic BTWM4 Front Load Washer
I have a Baumatic BTW M4 washing machine(4 yrs old). It wouldn't empty now lost all power to machine. cleared blocked filter changed fuse to plug etc still no power lights. is there a reset button etc? clutching at straws here. rgds
  • Baumatic Master
  • 12,061 Answers
Http://www.servicematters.com/maytag_library/docs/16007803.pdf
Above is a generic service manual, use this to troubleshoot your unit.Below is your user manual, for Codes etc. http://www.manualnguide.com/manual-get/12342/
When they do this, usually it is the "Brain" or a Sensor, that is inhibiting it from working, use the manuals and maybe you can sort it out.
Posted on May 01, 2010
AEG lavamat wont empty. Error code C2
I expect you will find the impeller is blocked in the outlet pump.
Apr 14, 2017 | AEG Washing Machines
What does e33 mean on a baumatic washing machine
not saying this is whats wrong with it i just found this on the internet............hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Dec 11, 2016 | Baumatic Washing Machines
My LG F1247TD5 washing machine has no power only 5 yrs old last month
first check the power supply to the plug in the wall, you may just have a dead machine.
Dec 21, 2014 | LG Washing Machines
My daughters washing machine of 3 yrs old keeps stopping and flashes F 18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine..
Open flap at the bottom righthand flap.
Keep big bucket handy for water.
Remove clear plastic attached to black tube (slowly)
This will empty water from washing machine.
Once empty - no water coming out from washing machine then open big opener next to tube and remove any objects inside( coins, buttons and such)
Put back clear plastic filler firmly inside as before.
Close big opener next to tube.
close flap
Turn machine programe knob to DRAIN.
Start washing machine.
Should do the trick....
Good luck
Apr 01, 2011 | Washing Machines
F02 Baumatic error not cleared Even when filter cleaned...?
Perhaps you need to check the outlet hose from the pump for a blockage, and of course, make sure the pump itself is working.
Jan 17, 2010 | Baumatic BTWM4 Front Load Washer
Bosch 1400 Exxpress washing machine : Turning off after a few sec
1. Switch off the machine and disconnect the mains power.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Oct 19, 2009 | Bosch Washing Machines
Error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
May 24, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic BTWM6 washing machine flashing F02 error
Feb 10, 2009 | Baumatic BTWM4 Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Baumatic btwm4 washing machine wont rinse and empty
If it wont empty its either a blocked pump/or filter. If it won't move on, heating element
Jul 11, 2007 | Baumatic BTWM4 Front Load Washer
Baumatic BTWM4 Front Load Washer Logo
206 people viewed this question
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
noel
noel
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
