Question about Presto 05460 ProFry Deep Fryer
I took the fryer out of storage. Got little response from unit
I filled it with oil. It turned on and beeped. I turned the heat to 375. The display went blank and the fryer became unresponsive. I removed the back and then I removed a relay. I had done this one other time when this error occurred and it fix it. When I tried again the unit beeped but I got no display. The unit is currently in this state.
  • 12,061 Answers
All element units are pretty simple,and you can think of them, as Heater Element, with a switch, in the Phase, that's Opened/Closed via a Thermostat, (& a sensor for said thermostat), and thus the Power is connected to the element. As such, it is easy to troubleshoot, you need a Multimeter, Using OHMS, Or Continuity test, simply trace out the circuit, from, plug, to element, along the Phase, Black, wire, USA, to the Element, the "Other" side of the Element is simply connected to return, or neutral. Also there is a "Thermal" fuse, that is there to protect, that too may have faulted, all fuses should be short circuit.
Posted on May 01, 2010
Unit is not turning on or calling for heat, why?
sounds like the elements have opened check with an OHM meter
Mar 23, 2017 | Cecilware EL2X15 Deep Fryer
I have a vulcan deep fryer and when i turn the knob up to 400 max it heat the oil but will cut off if i turn down to 375. the unit has been off. what part is needing to be replaced.
I'm unclear, if it has reached 400 you would expect it to be off at 375, until the temp drops below 375.
If I have misunderstood then apologies.
May 13, 2014 | Vulcan EF3 Deep Fryer
My flame keeps on going out on my turkey fryer it has a heat sensor on it how do i position the sensor so the flame doesnt go out
The heat sensor for your turkey fryer is preset to 375 degrees F. Once the oil reaches that temperature, the sensor turns the flame OFF, so that the oil will not boil over and ignite. Once the oil cools to 325 degrees F, the burner can be relighted . Use extreme caution when relighting the burner. Altering or repositioning the heat sensor would make the fryer unsafe to operate.
I'm sorry. I which I had better news for you. Always, err on the side of caution & safety when dealing with open gas flames.
Jul 06, 2011 | Brinkmann 815-3530-2 Turkey Fryer
Fryer will heat up at 350 temp setting but actual reading is 375. The problem we are having is that the fryer will heat up fine then when the burner goes of the pilot will also shut off. If however i run...
The thermostat is out of calibration and the hi-limit may be as well. I could give you instructions on calibrating the thermostat but the hi-limit is not adjustable at all. The hi-limit cuts off the burners and pilot in the event that the unit gets close to the flash point of the cooking oil. It should not cut out until 400-425 so either the fryer is occaisionally getting a lot hotter than you think or the hi-limit has gotten weak due to the erratic operation of the thermostat. I would recommend that you change both the thermostat and the hi-limit.
Dec 09, 2010 | Vulcan EF3 Deep Fryer
Imperial cif 40 single tank bouble basket deep gas fryer
When the whole unit shuts down including the pilot light the thermocouple is not working properly. The thermocouple is what tells the gas safety valve that the pilot light is lighted. When the thermocouple fails and does not send the milli-volt (mv) signal to the gas safety valve due a failure the gas safety valve turns off the gas supply. (i.e total shut down)
If you have a handyman around you can have him disconnect the thermocouple from the gas valve control and clean the mating area in the gas valve and on the bitter end of the thermocouple. After cleaning then reconnect the thermocouple. This sometimes corrects the problem. FYI you can get a thermocouple at most any large appliance parts supply. (You will need to the know total length) It would be even better to have the old one in hand during the trip to the parts store.
Thanks for using FixYa,
Kelly
Apr 24, 2010 | Imperial IFS40 Deep Fryer
My fryer will not heat up consistently. If i press the reset button, it heats up. But after heating up to a certain temp it shuts down and stops heating. There is power to the unit, it seems like a problem...
It probably is a problem with the thermostat. The reset button is probably a high limit. The high limit is a safety device to turn the fryer off if the oil gets too hot. Normally they will "trip" somewhere between 375 - 450 degrees F for commercial fryers. I would suggest placing a temperature probe in the oil and see what the oil temp is when it trips. If it trips at a temp below 375, it is a bad high limit. If the thermostat is set at 350 and the temp goes over 400 then the thermostat is bad.
Feb 03, 2010 | Kitchen Appliances - Others
The deep fryer does not heat up to 375 degrees. It only heats up at the lower temperatures. Can you explain what might be wrong with the fryer
Hello. It is likely that the thermostat on this fryer is off. try turning it to a higher setting and testing the temp. with a separate theremometer.
Nov 24, 2009 | Office Equipment & Supplies
Temperature never reaches 375
Pull the temp knob off and you should see a small screw in the middle of the stem. This is your calibration screw. Turn it about 1/4 turn to increase the temp. If you don't have one, then you may have an element that is out. Can you take the bottom off to see it. Also, there may be a wire that is not making good connection.
Jan 10, 2009 | Rival CZF530 Deep Fryer
Do not know how to use
Oil darkens with use the oil food molecules burn when subjected to high prolonged heat.
When frying foods such as fish or chicken use the oil once.
Do not filter oil over to reuse. Storing the oil in the refrigerator may extend the life of the oil, this should not be done ever. This process of chilling the oil and then burning the oil to room temperature causes excessive splattering furing the heat up.
Storing the covered oil in a cool dark place, for up to three months. ( remember to check oil when you use for color, smell, or excessive foaming. Throw out if there is signs of all the above.
This unit has a warranty for one year from the day of purchase.
Cooking:
When starting let unit reheat 7-10 minutes. This will get the heat to desired temperature. Re4ady light will cycle on/off during frying as temperature fluctuates due to food load.
Types of foods cooking: temperatures and time of cooking
Chicken strips 375 F. 5-8 minutes
Chicken pieces, bone-in 375 F. 15-20 minutes
Fish, battered 340 F. 8-10 minutes
French fries, frozen 375F. 3-5 minutes
F375F. 3-5 minutes
Onion rings 375 F. 3-5 minutes
Shrimp, breaded 375 F. 2-5 minutes
When frying frozen food if iced rub off lose as this can make the temperature of oil cool down. Pre-cooked frozen food cooks faster and does not come out oily.
I cannot wait to start cooking in mine as I got it for a christmas gift. Great recipes in the owners manual:
Apples fritters yum yum,beer batter for fish or chicken, deep fried chicken , chicken Kiev, quick doughnut made from biscuits, add topping of ground cinnamon and suger.
Dec 13, 2008 | Rival CZF625 Deep Fryer
Heating
Some Deep Fryers heat up faster than others, please see details below for pre-heating times: Non-Immersion Element (No element in the Oil): 25 to 30 Minutes Immersion Element (Element in the Oil): 7 to 10 Minutes Are you by any chance overloading the fryer? try smaller batches. Preheat the oven to 180 to 200 F. Heat the oil in the fryer to 280 or 290 F. In small batches appropriate to the size of the fryer (fries for a serving of 4 people may need to be divided into 2 or 3 groups), fry each batch for about 8 minutes at this temp. Remove to a holding bowl. They will look limp, nasty and oily. (This uses 1/4" square fries from baking pototoes cut with a standard mandoline.) When all the fries have been precooked, increase the oil temp to 375 F. Add the fries back to the oil in the same sized batches as before. It will take 3 to 5 minutes for them to crisp and brown. Drain, salt, and move to a cloth-lined bowl and hold in the 180 F. oven. Let the oil temp recover to 375 F. and cook the next batch in the same manner. Repeat, holding interim fries in the 180 oven, until all the fries are done. When all batches are done, toss to distribute salt and the new fries with old, and serve immediately. Properly done, all commercial french fries pale in comparison to these. However, I cannot guarantee that this method works with frozen commercial products. I always use fresh baking pototoes. That said, the frozen product should work to its optimal advantage when done in small batches with the first batches held in the warming oven as the other batches are done. If it still doesn't reach 300 F then by all means take it back to the shop and ask for a replacement. If you're out of warranty get an estimate for a repair. Good luck and bon apetite ;]
Jan 24, 2006 | Black & Decker DF200 FryMate Fryer
Presto 05460 ProFry Deep Fryer Logo
193 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
