Question about Nokia 2310 Cellular Phone
Nokia 2310 My phone won't ring but it does vibrate. It is showing what looks like a car above menu?????? this has come on this morning and the phone has not been touched?? help please
    Brigadier General:
  • 7,752 Answers
Change the profile to "normal" on the phone
Posted on Mar 27, 2008
SOURCE:
How to change from vibrate to ring?
Hi there.let me give you a hint.First open Menu >>Profile>>Personalise>>Check the Ringing Tone>>Ringing type should be"RINGING">> and Alert For should be "ALL CALLS".Try this this may help you.Good luck
Apr 18, 2012 | Nokia 6760 slide Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
My alarm of 2310 is not currently ringing. It is just showing the stop and snooze buttons. Please reply as early as possible.
The alarms on nokia phones don't ring when the phone is set to silent. Check the ringer mode. Are you sure the phone speaker is working fine?
Mar 05, 2011 | Nokia 2310 Cellular Phone
Ibought my nokia e63 a week ago. Now there is no sound when it rings and no vibration i did go to the settings and set everything the way its supposed to be. I did not let it fall or anything. I put my...
u can try this
go to profiles then select the profile u want to activate then go to its customize menu and incoming call alert type and select it ringing
Aug 23, 2010 | Nokia E63 Cell Phone
Cannot get phone to ring only vibrate
To change the Nokia 6133 to ring, do the following-
Select Menu > Settings > Profiles > Select any one profile that is available in your mobile. (Ex. General)
1. Menu > Settings > Profiles > General > Personalise > Incoming call Alert > Ringing
2. Menu > Settings > Profiles > General > Personalise > Vibratibng Alert > Off
After this activate the profile(Ex. General)
Menu > Settings > Profiles > General > Activate
After this the phone will only ring and wont vibrate.
If you want both then change the vibrating alert to On.
Good Luck.
Jun 04, 2010 | Nokia 6133 Cellular Phone
Nokia 2310
remove the battery for about a few minutes and restore it to factory default settings. Full charge your battery after that.
thank you for using fixya
CHARCOIS
Nov 19, 2008 | Nokia 2310 Cellular Phone
Turn vibrate on ?
let me sole it by steps do it step wise
press
1. menu 2. profiles 3. general 4. personalize
then move down to incoming call alert than select off
and move vibration select on
did i solve the problem
Jun 14, 2008 | Cell Phones
Nokia 2310 Cellular Phone Logo
63 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
