Question about Nintendo Wii Console
Wii consule will not read disc - Nintendo Wii Console
  • Nintendo Master
  • 2,404 Answers
Take a can of air and blow some into the drive to make sure there is no specs of dust or dirt on the laser. Then go ahead and see if it will read any games. If it doesn't then that means the drive needs to be replaced.
Posted on May 01, 2010
Testimonial: "done that didnt work but thanks any how think i better sent in off"
Trying to play nintendo on line. have a new wireless router/modem it is giving an error code of 52230 and says unable to connectg to server. any ideas?
Your nintendo consule without a technical malfunction should integrate to a network. The wii fii feature allows to network by wireless recognition of another consule on the network. The situation requires finding another consule owner to network with. Both consules would communicate by wii fii signals, only require recognising another consule owner that would allow device to device connectivity. keep in mind that, the error message is a computer message indicating a break in the link that could be created once another consule is recognised.
The error message would be intergrated into a network hub once each owner of the consule enable a feature on their device to accept communcation.
The wii fii feature only is advantage to the consule owner compared to connectivity that would have been performed by connection cables earlier in the invention of video gaming.
Advice
Find colleages with similar devices, inform them about wanting gaming network connectivity to allow possible network. keep in mind that, networking is a connection involvign entities where people are a requirement..
Your situation would be possible by human networking to make possible, device to device; that would only communicate when enabled features disabled.
Dec 01, 2010 | Nintendo Wii Console
Wii console does not read eny disk new or old
Try a cd lens cleaner you can get one at game stop or walmart.If that doesn't work you can replace the laser lens inside the wii consul.The screwdriver you need is a tri wing and you can get the laser lens at this siteNDSL games console, ds games console, NDSL games console_Video games Console_www.goldenbridge.hk
Mar 02, 2010 | Nintendo Wii Console
Disk stuck in wii consule
eject button press as many time as you want quickly as possible.
turn off the wii console unplug it and wait for an hour or so
then turn it back on and again to step 1 and pray it the disk comes out....
Jul 11, 2009 | Nintendo Wii Console
I cannot get to the main menu of my consule
It seems that your wii console is frozen it could either be the disc inside. If it is not the disc then I would contact Nintendo.
Apr 28, 2009 | Nintendo Wii Console
Unable to play my brand new wii fit
I was just being really thick!! Eventually I found the right button on the remote and there it was on the screen. Thanks anyway though, and I know where to find you again. Sure I will!
Apr 14, 2009 | Nintendo Wii Console
Disc stuck inside Wii Consule
Unplug everything from the system and the power cable from the wall or power strip, let it sit for about 5 minutes. Plug everything into the system first then the wall. Power should come on
If the disc does not eject, contact nintendo, the disc drive will need repair
Mar 15, 2009 | Nintendo Wii Console
Wii can"t read disc
If Wii gives can't read disc, so first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide,that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 14, 2008 | Nintendo Wii Console
Disc's not reading
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Jul 29, 2008 | Nintendo Wii Console
Wii
hello micky1965
Try holding down the eject button for at least 10 seconds after turning on the console. If that doesn't work (or you've already tried that). Try the following steps.
1. Unplug Wii from power outlet.
2. Plug in Wii again.
3. Press power button.
4. Press Eject button for at least 10 seconds.
5. If the disc doesn't eject try holding down the power button for 10 seconds and then the eject button again.
If that fails then either return the console to exchange for a new one or contact Nintendo consumer support. Info follows:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform:
| Nintendo - Customer Service | Contact Us! |
I wouldn't attempt to manually remove the disc (by trying to disassemble your Wii) as it may void your warranty. It could simply be a faulty console in which case Nintendo should replace it within 2 weeks (according to posts I've read). It seems to be a somewhat common problem.
If holding down the eject button doesn't work, there's really not much else you can do. Sometimes unplugging and replugging does the trick.
I've had problems with discs not ejecting and some combination of the steps I wrote above solved the problem.
riz.
althought i have a guide for opening inside the wii.?
Apr 08, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
78 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
