Question about Corinex AV200 Powerline Ethernet Wall Mount - Dual Pack (CXPAV200WME2) Network Adapter
Lights not on. no connection to internet, yet power to plugs confirmed
    President:
  • 1,070 Answers
Hello Sir,
If there is no Light Click here
To make Basic Test click here
Installation Tutorial Click here
If you Experiencing Problems Unplug Device and Reboot PC will mostly solve your Problem...Properly Configure it...
Thanks for Contacting FixYa...
Posted on May 01, 2010
LG 42LN5400-UA.BUSYLHR back lights not working, sound working, flashlight test shows video working.
This is a common problem for LG 42LN5xxx & 47LN5xxx LED TVs, the problem is defective LED back lights strips, it has nothing to do with main power supply & the main board.
Aug 31, 2017 | LG Televison & Video
New motherboard still no power
Remove the main battery and try again, next sub out the ram one at a time and test, I would sub out the power supply to be sure it is basically the only thing left.
May 07, 2012 | Dell XPS M1330 Notebook
I have used the Linksys CD to setup my wireless connection to e1000 wireless router; in diagnostics, I discover that I am connected to the router but not to the internet. I also try setting up ethernet to...
Make sure the Modem is plugged into the correct port on the E1000 (far left port labelled 'internet' on a yellow background). Unplug all the devices power cables and restart them in order from the wall (modem - router - PC/MAC) make sure the modem has link and activity lights flashing, if there is a light for 'internet' wait for it to be on before plugging in the router. You might want to call your ISP and confirm theres nothing funky with the line/modem.
Aug 22, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
I have a Zyxel Q1000z dsl router power light and DSL light on solid green however internet light is completely out not red or green or anything Qwest my service provider tested the line as good. I have...
If you have called your service provider and they have confirmed that the connection is good then there may be a problem with:
A- The router itself
B-The physical connection from the ISP's last access point to your router.
Your best bet would be to (if you haven't already) reset the router and wait AT LEAST 10-15 seconds before plugging it back in.
Another solution would be to go to the router configuration page and check the router logs to see when the problem first occurred, and what could be causing it.
Jul 09, 2011 | Zyxel P660HW-D1 Router
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
I have a lcd monitor problem, it wont turn on. the little light thats suppose to light up when you plug the monitor doesnt light up.. when i press the power button the green light appears for a sec and the...
sounds like a power issue with the monitor. try to remove and reconnect its power cord. If same thing happens, try using a confirmed working power cord like the one you use with the computer and make sure you test it out using a confirmed working power outket. If it has the same issue, would mean you need to get a replacement monitor. Refer to the vendor if it is still in warranty.
Aug 31, 2010 | Computers & Internet
I cant connect to the internet
How to quickly install and use your Belkin wireless G router 1. Step 1
Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
5. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jun 10, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
INetwork Password
ask your internet service provider
May 30, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I have At&T internet a motorola modem from them and a neatgear router rangemax WNR834B. AT&T helped me setup the wireless network. I think my router is bad since the power light does not light....
No solid power light = NO internet. Check and make sure router is plugged in. Try unplugging router for half a minute and plug it in again check and make sure the outlet works where you are plugging the router in and if still no power light you can contact Netgear support at 888-638-4327.
Apr 18, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
How to configure Linksys WRT54G router with BSNL's C2110 modem?
The Linksys WRT54G broadband router is one of the most popular consumer routers there are. Linksys makes configuring your router easy. This article will walk you through the initial setup options for this particular model, but many of the basics we talk about here can be applied to any router setup. Setting up the router consists of four basic steps, such as Testing your Internet connection, connecting your hardware, setting up the connection and power cycling the entire network. Aside, from setup, we'll also describe some security concerns so you can make an educated decision on the administration of your home network.
Test Your Internet Connection First While this seems like something you would not need to be, make sure your Internet connection actually works. If you haven't already, plug the cable modem directly into the back of the computer and make sure you can get onto the internet. You may need to reboot the machine first.
Connect The Modem and Router to the PC Now that we have confirmed the Internet connection works, the next step is to connect the modem to the router and the router to the PC. The modem will attach to the router's Internet Port. You will then attach the router to the PC via any of the four Ethernet ports in the rear. Check the LED lights in the front of the router to confirm all of the connections are properly made. The Power, WLAN, Ethernet Port to PC and the Internet should all be lit.
Configure The Linksys WRT54G Settings With all connection made, you will now need to login to the router via your web browser. Type 192.168.1.1 and hit enter. You should see the login screen. Leave the username blank and type admin as the password and hit enter.
You will now need to configure the router's connection to the Internet. Under the Setup / Basic Setup section, make sure the router is setup to Automatic Configuration - DHCP. This allows the router to receive an IP address from your Internet Service Provider.
Next, go to the MAC Address Clone tab in the same area and enable Mac Address Cloning. This allows the router to clone your PCs MAC address, as the ISP may require this.
Power Cycle the Router and Modem Now that everything is configured, you'll want to power cycle everything. This is done to make sure everything has an IP address from the modem all the way through to the PC. To power cycle, shutdown everything. Unplug the modem and router power source. Shutdown the computer. Plug in the modem and wait for all green lights. Next, plug in the router and wait a few minutes until its lights are also green. Lastly, boot up the PC. You should have an Internet connection.
Change the Linksys WRT54G Router Password You noticed when setting up the router, that there was a default username of nothing and a password of "admin." Be sure to log back into the router once everything is running properly and type in a username and change the password. If you don't, a hacker that sees you have a WRT54G router could login to the router with the default credentials.
Jan 10, 2010 | Linksys Wireless-G WRT54G Router
Corinex AV200 Powerline Ethernet Wall Mount - Dual Pack (CXPAV200WME2) Network Adapter Logo
46 people viewed this question
Top Corinex Computers & Internet Experts
David Payne
David Payne
Are you a Corinex Computer and Internet Expert? Answer questions, earn points and help others
