Question about Toshiba Satellite A45-S120 Notebook
I get an error 00 ide something than the screen changes to trap 0000000d general protection fault
    Scholar:
  • 78 Answers
Hi johnnygriff5
The boot loader files are either corrupted or missing. To repair this problem, boot with the Windows XP CD-ROM and choose the option to install. On the next screen, choose repair to repair your Windows installation. When the repair process is finished, you will be able to boot back into your operating system without losing data or having to reinstall software.
If however this doesnot work then, please perform the following steps:
1. Insert the Window XP installation CD-ROM in the CD drive and boot your PC from the CD-ROM. 2. When the Welcome to Setup screen is displayed, press R to open Recovery Console. 3. Next, press the number key that corresponds to the operating system installation you want to repair. (This is required only when you have multiple operating systems on your PC.) 4. Login using a user with administrative privileges to your system. 5. Next, on the Recovery Console screen type the following commands ie chkdsk then fixmbr and press Enter after each command to execute them.
If you have some more questions, please let me know. Otherwise, please leave positive rating and feedback. Thanks :)
Posted on May 01, 2010
TRAP 0000000D GENERAL PROTECTION FAULT.. AND MY SYSTEM NOT START
trap 0000000d general protection faultCall to this NO :9964543365
Aug 15, 2012 | Microsoft Windows 7 Home Premium 64BIT...
How ifix a fatal error
Below is a listing of the more commonly experienced processor exceptions ranging from 00 to 0F.
00 = Divide Fault
Occurs if division by zero is attempted or if the result of the operation does not fit in the destination operand.
02=NMI interrupt
Interrupt 2 is reserved for the hardware Non-Maskable-Interrupt condition. No exceptions trap through interrupt 2.
04=Overflow trap
Occurs after an INTRO instruction has executed and the OF bit is set to 1.
05=Bounds Check fault
The array Index is out of range
06=Invalid Opcode fault
This error can be caused by one of the below conditions.
  1. Processor attempting to decode a bit pattern that does not correspond to any legal computer instruction.
  2. Processor attempts to execute an instruction that contains invalid operands.
  3. Processor attempts to execute a protected-mode instruction while running in virtual 8086 mode.
  4. Processor attempts to execute a LOCK prefix with an instruction that cannot be locked.
07=Copressor not available fault.
This error can occur if no math coprocessor is present. This error can also occur when the math coprocessor is used and a task switch is executed.
08=Double Fault.
This error occurs when processing an exception triggers a second exception.
09(OD)=Copressor Segment Overrun.
Floating point operand is outside the segment.
10(0Ah/0A)=Invalid Task State Segment Fault
Can be caused by a number of possibilities as Task State Segment contains a number of descriptors.
11(0Bh)=Not Present Fault
The Not Present interrupt allows the operating system to implement virtual memory through the segmentation mechanism. 0B fault occurs when this segment is not available.
12(0Ch)=Stack Fault
Occurs when instruction refers to memory beyond the limit of the stack segment.
13(Odh)=General Protection Fault
Caused by any condition that is not covered by any of the other processor exceptions. The exception indicates that this program has been corrupted in memory generally resulting in the immediate termination of the program.
14(Oeh)=Page Fault
Occurs when a paging protection rule is violated (when the retrieve fails, data retrieved is invalid or the code that issued the fault broke the protection rule for the processor).
16(10h)=Coprocessor error fault
Occurs when an unmasked floating-point exception has signaled a previous instruction.
17(11h)=Alignment Check Fault
Only used on 80486 computers. Caused when code executing at ring privilege 3 attempts to access a word operand that is not divisible by four, or a long real or temp real whose address is not divisible by eight.
Find out the reason of Fatal Error if that is due to Software related then go in safe mode and uninstall the software recently installed or udate them/patch them. or if the same is related to hardware then unplug the recently added hardware,
please vote
Aug 21, 2011 | Computers & Internet
How to farmat BIOS System, i set to boot from CD but i still yet an receiving some mess of numbers trap 0000000====== GENERAL PROTECTION FAULT=========== TR=0028 Cr0=0000000 does are the...
A general protect fault is when processor architecture is violated by any of the programs that are running. If it is only occurring when booting from CD, then the drive is probably not supported.
Mar 14, 2011 | Computers & Internet
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
E3 The washer vibrates
hi.....
the following table provides you the all error codes and the reason causing those error codes.....
Washing Machine Failure
Code
Condition Check/Repair F1 Water supply/low water fill · Check water supply to machine
·Replace water inlet valve F2 Water level too high · Plugged/Bad water pump
· Faulty water valve F3 Pump problem Check pump trap and clean. F4 Thermistor problem · Open thermistor, replace
· Bad wiring to thermistor F5 Fault in thermal cutout or heating pause fault. Selected temperature not reached in 90 minutes · Check heating element
· Check thermostat F6 Motor fault · Check wiring to motor
· Replace motor if necessary F7 Door lock release fault · Bent pull-rod for door latch
· Bad door latch solenoid 00 00 Machine did not spin Check load for out of balance Redistribute load and restart i think my solution will be definitely will be helping you......if you are satisfied with my solution then rate for me...
thank you for using fixya....
Jul 20, 2009 | Samsung Washing Machines
Trap 0000000D =========== General Protection Fault ============
Trap is the one of the hardware intrupt..this means u have any hardware prob.
Mar 28, 2009 | Dell Latitude C500 Notebook
'GENRAL PROTECTION FAULT'error seen when pc boot with xp
This is what the error says ?
tr=0028 cr0=00000011 cr2=00000000 cr3=00000000
gdt limit=03FF base=00017000 idt limit=07FF base=000017400
cs:eip=0008:2FFF3066 ss:esp=0010:00060E7B errcode=0000
flags=00010013 Cy NoZr IntDis Down TrapDis
eax=00000F44 ebx=00000004 ecx=00000005 edx=00000000 ds=0010 es=0010
edi=00070000 esi=000000A1 ebp=00000000 cr0=00000011 fs=0030 gs=0000
To repair this problem,try boot with the Windows XP CD-ROM
software.
Jan 01, 2009 | IBM P4 3.2/512/40/CD/XPP DT M-Class...
Computer won't run windows and come up with a trap-handler error
on the IDE Port, set the jumpers to the hard drives/cdrom on CS(Cable Select) this lets the BIOS and the ribbon cable decide which is primary (Master) and which is secondary (Slave) on that IDE cable. if they were configured wrong you would get an error.
If the IDE channel is no good, try switching the primary and secondary IDE ribbon cables.
May 26, 2008 | Intel Motherboard
General protection fault
based on limited description of the issue possible causes - 1. memory corruption 2. corruption of bios 3. boot sector on hard disk failed or crashed
Oct 03, 2007 | HP D530 PC Desktop
Burn error
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Sep 03, 2007 | HP Media Center m7250n (ED842AA) PC...
Toshiba Satellite A45-S120 Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
