Question about HP Computers & Internet
Computer have hp brand but this system don't get display when monetor cabel is connected to cpu
  • HP Master
  • 2,404 Answers
Try different monitors hooked up to the computer. If your not getting any video from any monitor then at that point. Try unseating and reseating the memory one stick at a time in each slot one at at time. Try turning on the computer after each reseat. If that doesn't work then try unseating and reseating the CPU and see if that makes the computer turn on. After this, make sure only the power supply is hooked up. If you still can't get video then that means the motherboard is bad and would need to be replaced.
Posted on May 01, 2010
When i turn on computet, my cpu,mouse, keybord all hardwear run but my moniter don't show anything. my moniter is always run but in my cpu mistek
are your monitor okey.try with a other monitor if it work your monitor is brooken.if not you have a brooken videocard.
all cabels should allways be seated tight.
Jun 10, 2013 | Computers & Internet
When i supply power in my hp 1502 desktop and connect it with cpu than my desktop scree only show its going to sleep
1.check with a other monitor.
2.check the cabels should be seated tight.also the videocard should be seated tight.
3.the videocard or the monitor can be brooken check with a new or other monitor first.
Apr 17, 2013 | HP 1502 LCD Monitor
Nc6220 did not display unless i pres down the proccesor
The processor sounds as if it is not being held by the CPU locking device. Get it re-installed and you should be okay. It is just a case of removing the cpu fan and heatsink ( while the power lead is unplugged of course) lift the locking lever (dependinding on the processor type) and reseat the processor, lower the lever and lock in place. try to give the cpu a wiggle, but not too hard, as long as it doesn't move then rebuild the computer and try it out. Good luck, and don't try it as if you are removing a six inch nail with a mallet. It should come to bit easy enough.
Jan 25, 2012 | HP Computers & Internet
Sorry about my english... when i turn on my hp mini 210-1170nr it just start cpu fan and power on the caps lock light... just that... no boot no display... just black screen. anyone know how to fix it.
1.Mo Bradley says do this:
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS
2.That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
3.Did this help you? If so Mo Bradley has one more quick tip to save your pocket.
I would like you to save on the high cost of replacement printer ink and I implore you not to buy Original Brand replacement ink. This is the rip off of the century and the Original Brand companies are not even ashamed. Try this website http://www.usainktank.com/ for ink which is mostly under $4.00 each (even HP ink) or if they don't have your printer model try some of the other suppliers of off brand printer ink. In the past I have used http://www.4inks.com/ and http://www.123inks.com/. They all have good quality off brand cartridges that will save you so much money.
Sep 28, 2011 | HEWLETT-PACKARD HP Mini 2101170NR Notebook
Not connect the monetor to cpu
Good day..! If its signal not connected to the cpu,you better check the video card,or else you can use another one,but if its still not working,you can cleaned it up using blower fan.or you can replace another mother board coz the problem would be your vga port..tnx.
Aug 17, 2011 | Intel Motherboard
My magellan 1424 showes a pic of a cpu with a usb cabel and a pic of the gps and that all it showes it does nothing else
The pictures that displays on your screen is a message asking you to get your system connected to a computer, then you either update the software, download a new software for it or you update your current software.
Try to reset your gps first before you connect it to a computer. To reset your gps device, you need to hold the power off/on button for about 15 seconds, then it will restart itself, then it will load normally. If it does the same thing, then you need to connect it to a computer and download a new software for your device.
I hope this information was helpful.
Dec 31, 2010 | Magellan RoadMate 1424 GPS Receiver
Hp w1907 monitor does not detect any input and goes into sleep mode. checked wiring and connections -- looks normal. No trouble until today.
try to connect the monitor to another working PC, or to a laptop monitor socket, if it works there... then there is a prblem on you PC display driver or display card inside your PC, try to connect another working monitor to you trouble PC and check if that works.
Dec 07, 2009 | HP w1907 LCD Monitor
Computer won't turn on
check your monitor connection and memory ram
Jan 06, 2009 | HP Compaq Presario SR1420nx...
HP desktop- is not starting up.
Let assume that the machine is fine. Is the display powered? Is the data cable from the display correctly connected.
The reason I am assuming your machine is fine is because it a name brand box. And when a video card fails on an HP you get a series of beeps from the computer. The same goes with the CPU and memory.
So if the machine is not beeping, it's generally one of two things. Connections or, sadly enough, a dead system board.
Hope this little bit of direction helps,
Paul
Aug 26, 2008 | HP Computers & Internet
Computers & Internet Logo
42 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
