Question about Sony Playstation 3 (PS3) Console
HDMI Hey i have hdmi it works properly sometimes....but other times d sound is stoping and starting every 2 seconds! very frustrating its like it works when it wants....any suggestions????? TNX
  • 21 Answers
The connection may be loose. Try buying another HDMI cable. The sell very cheap (like $10) on Amazon.
Posted on Mar 25, 2008
Mitsubishi wd-60737 HDMI port 1 connected to cablebox. Screen is black and no sound. Cablebox is on, all cables connnected correctly and was previously working. Nothing new was done.
have you tried resetting your cable box? you can do this usually by either holding its power button in until all 3 lights light up, or by unplugging it from power , wait @ 30 seconds & plug back in .
Feb 07, 2015 | Mitsubishi Televison & Video
I can see in RCA output but canot in HDMI
Hey there! My name is Becki Barned, and I am with Dish Network customer service. This may have already been resolved, but if not, or if you have any other questions, I would be more than happy to help you out!!! There are a few reasons that you could be having problems with your HDMI cable. One being, that the tv may not be on the correct input. Remember, your tv must be on an HDMI input in most cases! Another reason, of course, could be that your cable is corrupted, or not working properly. Try unplugging the receiver from the power source for about 10 seconds, and try, if you're able. a different spot on the tv for the HDMI, then match the input to that. (Most tvs are labeled HDMI 1/2 so forth). If that doesn't work, or you have any other questions, blog back!!!!!
Aug 14, 2010 | DISH Network ViP 211 DTV Receiver
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
I have a denon avr 2308. The sound stoped working
when using an hdmi input, make sure the "input mode" is in 'hdmi' or 'auto'. i am sure you can remedy your issues with a trip through the setup menu. it very extensive. good luck
Feb 10, 2010 | Denon AVR-2308CI
Sound cuts out in Westinghouse LTV-32w6 HD TV
is it ran through a HDMI cable?
sometimes the source is at fault or it could be a bad hdmi cable or maybe a bad hdmi port. if your using a hdmi try plugging it into another hdmi port and see if that helps
Jan 06, 2018 | Westinghouse Televison & Video
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
