Question about Sony PlayStation Portable (PSP) Console
I play my psp untill out of battery...then it cannot be charge
I have checked the charger but it seem that there is no problem with the charger. now i cannot on my psp because the empty battery sign keep turn on the psp screen.please help me.
That means there is a problem with the charging port in your psp,try going to a cyber cafe to get it fixed
Posted on Dec 08, 2010
Psp wont charge, how do i fix it
cheak that the bettery is out of order if this is not than change the jak of charging
Aug 26, 2013 | Sony PlayStation Portable (PSP) Console
I HAVE A PSP 1002 (ORIGINAL MODEL). the problem is that i tried charging the battery with the wrong charger (i had temporary lost the proper psp charger) this seemed to work for a little while until one...
i do believe you have burnt out the inverter within the system :( i dont have an answer for you on how to persue a fix but i do wish you good luck .......keep in mind these are very cheap new nowadays so dont pay a big amount to fix it if possible ok :)
Jun 03, 2011 | Sony PlayStation Portable (PSP) Console
I have a psp and i dont know if the psp is broken or is it my charger or battery please help!!!!!!! sony model psp-110 battery pack 3.6
Solution 1: Try to borrow from your friend psp charger and charge it if charging. this maybe the problem.
Solution 2. Try to borrow replace the battery if it will charge. This may be the problem.
Otherwise the problem would be the psp unit itself that you are using while at battery charging. Hence your are playing and moving, you have tendency to damage the charging port of your psp. This maybe the problem and need replacement of parts.
Dec 19, 2010 | Sony PlayStation Portable (PSP) Console
The PSP will not stay charged.My son used to always play it while it was charging. I was wondering if this would bring about an issue with the battery.
During charging the battery gaining some power to recharge itself.When you use it while charging the battery forced to give you enough power to operate the PSP.It seems your are using power directly from charger instead from battery, and It could damaged the cell. All you can do is to replace it with same model battery and dont play it while charging.If possible turn off the unit while charging.God bless
Nov 04, 2009 | Sony PSP (Piano Black)
I cant charg my psp i cant find my charger
When you say you can't cahrge it, do you mean on your PC, PS3 or with the charger? I don't think the PS3 charges the PSP, I have no idea about the PC, but if the PSP doesn't charge using it's charger, it is either the battery, the charger, or the psp charger outlet. If it is the battery, buy a new one. If it is the charger outlet, it is a good idea to have 2 working batteries and to buy an external charger at game crazy, game stop, or from sony. This way, you can switch out batteries while playing, like me :). If it is the charger, buy a new one.
I would suggest first trying to buy a new battery. If it works, you are good to go and your old battery was broken, otherwise your charger/ charger outlet is broken. Buy an external charger. Then, you will be able to charge the batteries while one is in the PSP.
A new battery and an external charger cost about $70, but it is worth it. I hope i helped.
Sep 05, 2009 | Sony PlayStation Portable (PSP) Console
Can i play my psps on the charger
Yes u can if u dont play on the psp wen charging it will take about 1hour but if u play on it it will charge slower it will take about 2hours
Apr 24, 2009 | Sony PSP (Piano Black)
Ok i just bought a new psp slim battery and a new charger and my psp wont charge and i dont know what to do but, i do have a psp slim 2001 (ice silver) and i bought a psp charger and battery thats 2000 so...
this is easy i solved it! buy a charger from gamestop that you have to take the battery out and then put it in the charger and charge it that way! that way if your fuse inside your psp is out it will charge the battey without putting it in the psp so all you do with the item is: take your battery out, put it in the alternative charger from gamestop (does not come with psp slim 2001 or 2000) plug the charger in the while charge the battery then bam!! there you go problem solved have a fun time playing your psp!
Apr 12, 2008 | Video Game Consoles & Games
PSP CHARGING PROBLEMS
The way to properly break in a lithium Ion battery is to run it dead before you recharge it. Then fully recharge it and run it until it's dead again. Do this about 3-5 times and then the battery is properly broken in. If you charge it before it dies on a new battery you can build what they call a "memory" where the battery thinks it's fully charged however it's only maybe half charged and you will lose alot of life out of your battery. So make sure you properly break it in.
Feb 02, 2008 | Sony PlayStation Portable (PSP) Console
Psp battery problem
the problem 's if u kept ur psp battrey without changing the battery it will bad , you have to wake up the battery by open the battery ,you remove the battery from the case .use solding iron to remove it after that , use ur psp changer to jump start the battery for just 5 min , after that solder it back it will start working ,,,,,,, bye
Dec 20, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
93 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
