Question about Panasonic KX-TG5777 Phone
I'm unable to register to base unit, I tried all
I'm unable to register to base unit, I tried allthe instructions given manual - i'm getting at the end error!!
1) On handset, press OFF, MENU, #, 1, 3, 0. Handset display should show as follows:
*Skip this step when handset already shows as above.
2) On base unit, press INTERCOM for 3 sec until the IN USE LED flashes.
3) On handset, press the OK button. Then wait until the handset display changes as follows.
@ the it say error!!!
SOURCE: handset wont register
Unplug the battery and try again. Worked for me.
Posted on Jun 17, 2007
SOURCE: Handset can't find base.
I just got a 3rd handset for the same phone system and were having the same error message,,, the at&t help line does not know what it is,.,. We returned it once and got another one because of the same problems, and were still having it.. AT & T help line said to return it again and try another one .. then he actually said to replace the whole phone system .. thats easier said than done! we paid 199 plus tax on the system and then another 81.00 for the third handset!
Posted on Jan 02, 2008
SOURCE: VT 2461 Won't let me register new handset
Rosehello's solution worked with one additional step for my handsets...After re-programming all of the 4 handsets, I had to unplug the base unit one more time and then it reset. Until that time it would only show"AL" and would not function.
Posted on Jan 25, 2008
SOURCE: Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Posted on Jun 23, 2008
  • 35 Answers
SOURCE: register handset GE DECT 6.0 27918 (Lost Manual)
http://www.home-electronics.net/ge/pc/IB/28112EE2_IB.pdf Online Manual
Posted on Apr 12, 2009
I am unable to set handset to work with the base. Its panasonic KX-TG5933Al
Registering a handset
Important:
If you accidentally assign another
handset's extension number to the base
unit, the originally assigned handset
stops functioning. Confirm the extension
number of the handset by placing it on
the base unit or charger. Lift the handset
from the charger before registering.
1 Handset:
{MENU} i {0}{0}
2 Base unit:
Press {SELECT} until the desired
extension number (H1, H2, H3, or
H4) is displayed on the base unit, then
press and hold {CALL} until the
CHARGE indicator flashes.
LH4 can be used if you have 4
handsets.
LAfter the CHARGE indicator starts
flashing, the rest of the procedure
must be completed within 1 minute.
3 Handset:
Press {OK}, then wait until the handset
beeps.
For futher information, see the phone manual at: http://dl.owneriq.net/3/3cd5d5a0-865d-4a28-8a1f-91f144108d9d.pdf
Mar 22, 2011 | Panasonic Computers & Internet
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
Mar 21, 2008 | Vtech IP 811 Cordless Phone
Can not get the second handset to register to the base
This is the registration procedure
Step 1: press MENU-6 and select 3 “SET BASE”
Step 2: press the REG key on the master base
Step3: press register to finish the registration procedure.
• After the registration complete, handset 11 and handset 21 can
2-WAY intercom with each other
If issue persists reset the unit start registration by using 2nd unit that currently unable to register. if issue continues please inform for further troubleshooting
Good Luck
Jan 01, 2008 | EnGenius SN 920 Ultra Cordless Phone
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
No link to basse
one of the phones has a no like to base error. I have put it on the base. Taken the battery out and replaced. What's up?
Feb 14, 2009 | Panasonic KX-TG5632 Phone
BT XD5500 manual
BT Freelance XD 5500
Resetting the base & handset/s on a BT Freelance XD5500:
Hold the Find button on the base unit until you get a double beep then
tap the Find button 7 times.
On the handset:
remove a battery
hold the menu key and refit the battery
screen says SW VERSION
press up arrow key until screen shows REGISTER CLEAR
press menu
press menu again and wait for OK to appear
remove a battery and refit
Registering the XD5500 handset.
Then register the handset to the base as follows:
Hold Find button on base unit until you get two beeps
On handset:
Press menu
Scroll to register
Press menu
Scroll to Register Base
Press menu
Press 1
Wait
When it says PIN ? Enter 0 0 0 0 (four zeros) and press menu.
Note:
If you have more than one handset then repeat registering the handset to the base for each subsequent handset/phone.
If this procedure fails to solve the issue, then you have a unit with a
fault and if it is less than a year since purchase the retailer should
change it for you.
Aug 03, 2008 | Lands Phones
Jun 22, 2008 | Panasonic KX-TG2356 Cordless Phone
Panasonic Phone KX-TG6700B base unit Problem
FROM PAGE 38 of the manual:
If "No link to base. Move closer to base, try again" is displayed, even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit..
HAVE BOTH THE HANDSET AND THE BASE UNIT NEARBY DURING REGISTRATION.
FOLLOW STEPS 1 AND 2 LISTED BELOW. YOU HAVE ABOUT 1 MINUTE TO COMPLETE THEM.
1-Base unit:
Press and hold [HANDSET LOCATOR] until the CHARGE indicator flashes.
2-Handset:
Press and hold [FLASH/CALL WAIT] until "Handset Registering" is displayed.
-When registration is complete, a beep sounds from the handset.
-Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
If... the handset beeps three times and "ERROR!" is displayed, an error occurred. Try again from step 1.
You can stop registration by pressing [OFF] on the handset, and pressing [HANDSET LOCATOR] on the base unit.
Jan 10, 2008 | Lands Phones
ID Conflict with Base 1 error
hold the volume and intercom buttons together the in use light will come on and then go to menu on handset press 6 then 1 to regester that should work i just talked to a friend with a telecom buisness and he told me what to do with mine good luck
Jan 08, 2007 | EnGenius SN 920 Ultra Cordless Phone
Panasonic KX-TG5777 Phone Logo
52 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
