Question about Canon PIXMA iP2000 InkJet Printer
How can fix if waste ink absorber is full for Canon PIXMA IP2000 ?
  • 4,041 Answers
Hi there Ok. Canon PIXMA IP2000
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 01, 2010
  • 70 Answers
SOURCE: Canon Pixma ip2000 saying waste ink absorber almost full
This is quoted from cannons website about your issue.
"This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
Here's the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10237&kbpage=yes
So what they are saying more or less is throw out the printer because it's going to cost more to replace the absorber than to just buy a new printer.
If you ak me it's just another way these printer companies screw customers. Just my opinion.
Sorry about the bad news but at least you have your answer.
Sean
Posted on Mar 12, 2009
  • 83 Answers
SOURCE: Ink waste absorber is full. Canon IP2000. How do I repair it?
Well, at some point you will need to either replace or wash the absorber pads in the printer - but you can reset the warning as follows:
1) Turn the printer off
2) Press and hold the <resume>button
3) Press and hold the <power> button
4) While holding down <power> release <resume>
5) With the power button still held down, press <resume> twice more
6) Release the power button
7) Press and release the <resume> button 4 times
8) Press and release the <power> button twice
At this point, the printer should come back online with the waste ink warning reset
Personally, I would only do this once before actually changing the ink absorber pad...
Posted on Aug 31, 2009
nethload
  • 22 Answers
SOURCE: The message 'waste ink absorber' nearly full
solution found!!
> this is copy paste from some other message and it works
> and for now it's not only temporary.
> I have a temporary fix (doesn't keep without power):
> 1:Unplug power and USB
> 2 Open door and hold power button.
> 3: Connect power.
> 4: Close door, then release power button
> Connect USB and an press power to use.
> Print instructions and stick it to your printer
Posted on Oct 27, 2009
pagebor
  • 2785 Answers
SOURCE: Printer shows warning
plz check the website http://www.fixyourownprinter.com/forums/inkjet/50418#1
Posted on Nov 18, 2009
pineworks
  • 4041 Answers
SOURCE: My Canon PIXMA iP2000 photo printer Waste Ink Absorber
Hi there try see if this will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Posted on Feb 13, 2010
Waste ink absorber is. full. How do I empty it?
The waste ink absorber can sometimes be removed and cleaned out and put back into place. Although it is not always easy to get at. Usually once this happens it is time for a new printer. You can also contact Canon and see if they have a replacement part for this.
May 28, 2010 | Canon PIXMA iP2000 InkJet Printer
Nov 18, 2009 | Canon PIXMA iP2000 InkJet Printer
Reset ip2000
1. Turn off printer
Oct 10, 2009 | Canon PIXMA iP2000 InkJet Printer
How will i clean the ink waste absorber and reset it
use this link click here
this wil help you in cleaning the waste ink
you can also take halp of the following link
Jul 27, 2009 | Canon PIXMA iP2000 InkJet Printer
My printer canon pixma ip2000 wont print there is a message on the monitor saying that my ink waste absorber is full
follow the link
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Jul 27, 2009 | Canon Office Equipment & Supplies
The waste absorber is full
Call Canon at 732-521-7230 and they will sell you a new ink absorber pad. You will need the reset code for your model printer. Find this by searching for canon used ink tank. One of the results should match your machine. You can also take out the pad(It can be messy so wear gloves), wash with water hose, let it dry completely, and reinstall it in the printer.
Jun 10, 2009 | Canon PIXMA iP2000 InkJet Printer
WASTE INK ABSORBER IS FULL FOR CANON PIXMA iP2000
The machine needs to be taken in for the waste ink absorber to be replaced
Oct 03, 2008 | Canon PIXMA iP2000 InkJet Printer
Waste ink absorber
hi i am a certiffied Canon repair tech for this model. this is true this will reset the error but doing so without replacing the waste asorber pad in the bottom of the machine will cause your machine to backup waste ink into the the printing area of the machine and will start smuging ink on the page. the waste absorber is fairly cheap but the labor varies from shop to shop. there are independent Canon repair shops throughout the world. you can call 1-800-ok- canon or look on the canon website. hope this help to clairify.
Dec 22, 2007 | Canon PIXMA iP2000 InkJet Printer
Pixma ip2000
waste ink absorber is full what can i do
Nov 29, 2007 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
770 people viewed this question
old marine
old marine
