Question about Boating
I have a 1989 sea ray boat. Does it have no power to the coil?
  • 5,537 Answers
If you look at the coil you will see small wires on either side. One side is a ground and the other is power. Depending on the brand of outdrive you have the wires are color coded.
You should be able to see the color of the wires on the "Plus" side at the coil. Then follow the wiring loom back to the switches hanging by the shift cables on the engine. There are also wires on the UP/DOWN safety switches of the outdrive.
The outdrive must be down somewhat for the safety switches to release the ignition LOCKOUT. This is done because the driveshaft will snap if you start the motor with the outdrive up. Look for matching color coded wires to match the small hot coil wires.
The switches on the shift cables will LOCKOUT the starter solenoid so you can only START in neutral. Look for the color coded wires from the coil to see if they are on the correct set of switches. It is possible someone made a redundant connection and combined the ignition with the starter cutoff.
Posted on May 06, 2010
Trim motor will not work on my 1998 sea ray 100 horse power boat
CHECK YOU HAVE POWER TO THE MOTOR USING A TEST METER OR A BULB.
If you have power to it remove it, strip it down and see if you can see what is wrong, or take the unit to a marine engineer.
Jun 17, 2017 | Boating
1995 StarCraft 20ft bowrider. Where can I get an owner's manual?
Boat Manuals Now Available Free From Vessel Vanguard ...
www.passagemaker.com/.../boat-manuals-now-available-free-from-vesse...
Nov 14, 2013 - Boat owners are often frustrated by the diffi. ... I ask for a boat manual1995 20 feet limited sea ray . How long does it take if it is not in ... I am looking for theowner's manual to a 17ft 1992 Starcraft Bowrider. Jonathan Bonar ...
Nov 03, 2015 | Boating
1996 29' Sea Ray Sundancer
Maybe Sea Ray can supply the specifics.
Mar 05, 2014 | Boating
1989 maxum boat manual
CHECK COIL OUTPUT WHEN IT STOPS RUNNING. A HEATED COIL CAN HAVE INTERNAL WIRING THAT LOOSES CONNECTION AFTER HEATING UP
Jul 21, 2013 | Boating
Installing amp on sea ray boat
remote wire is in the wrong location most likely
Jun 17, 2013 | Car Audio & Video
Can u use automotive spark plugs on tune up for i/o 1979 sea ray
Use only the spark plug recommended by Sea Ray or the engine manufacturer. Spark plugs in a marine envireonment need to meet special environmental conditions.
Thanks for your quesiton @ FixYa.com
Mar 25, 2012 | Boating
Hi trying to find out the correct way the water hoses run on a 302 windsor with a mercruiser leg in a sea ray boat
i m search Compaq presario c700 driver but his not find. pls u check it.
thanks
chandra ketu rai
09955129198
Mar 12, 2010 | Boating
Loading back on traiker
Float on style trailers are designed with immersions depths and vertical guides to allow the boat to be driven onto the trailer. But not at full throttle, only enough power to move the boat over the bottom rollers/guides. Some trailers are designed to have the boat winched onto the trailer. For this style, you drive to boat to a starting point and then use the winch to pull the boat the remaining distance. These sometimes have a release mechanism and hinge/pivot point to allow the back of the trailer to drop below the normal towing position to make recovery easier. As the boat is winched into position, the weight of the boat will cause the trailor to pivot and return to the towing position.
Dec 01, 2008 | Sea and Sea Sea Eagle Inflatable Fishing...
Load back the fisihing boat on the trailer
Boating Logo
96 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
