Question about Epson STYLUS CX3900 All-In-One InkJet Printer
Printer does not switch on power supply and connecting chord OK
    Genius:
  • 1,044 Answers
Try the connecting power cord on any other device just to make sure that it is working. Check the wall out let and ensure that it is working. If the above is OK then check the main switch on the printer. If it not working then you have to get it replaced. There is no other reason for PRINTER NOT GETTING ANY POWER.
Posted on May 01, 2010
How to get power to HP Deskjet 6540 printer?
sounds like either the fuse on the power supply is blown or the power supply is bad, needs to be serviced
Nov 23, 2015 | HP Office Equipment & Supplies
Hp c5280 wont switch on, its been working well when last used this morning.
Disconnect the power chord from the back of the printer. Wait for 40 seconds and connect it back and check if it is warming up or not. If not the press power key for few seconds and see if it turns on or not.
If not then check if the adapter is getting warm or not after it is connected to wall outlet.
If adapter is warming up then try another power chord and check..
If both power supply are getting warmer then problem is with printer hardware and if printer works with another power chord then replace the damaged power chord
Feb 25, 2011 | HP Photosmart C5180 All-In-One InkJet...
Power is not coming on sony LCD TV. No standby power after switch on.
hi,
check the power chord first. also check whether there is power in that power socket to which ur tv is connected. if all these ok ur tvs power supply card have some problem. u can fix it only if u have an electronics basics. you can contact me through fixya.
ok
Dec 16, 2010 | Sony Bravia KDL-32V4000 32 in. LCD TV
Keeps rebooting
Hi, Please check if it is connected to a wall outlet or to a surge protector...If it is connected to a surge protector then connect it to a wall outlet.....
- If it is working then fine....If not then remove all the cartridges...disconnect the power chord from back of the printer and then from wall outlet......wait for 40 seconds then connect the power chord to wall outlet first and then to the back of the printer....
- If working fine then ok or else check adapter is warming or not......and check with different wall outlet and with different power supply....
- Now do the following re-sets :
A) Disconnect the power chord from the back of the printer
B) Press and hold # and 6
C) While holding these keys connect the power chord to the back of the printer and when you see that printer is warming up then release the keys.....
Or else replace the printer.
And also some of the electrical components used to build the logic board in the Cxxxx all in one printers about 2-3 years ago is failing. In my C6180 (with the same problem), there were 4 capacitors (see green cylinder shaped component in the attached - the bulge in the top indicates failure, and that this is the likely the cause) that I replaced (cost was about 60 cents!). If you are not comfortable doing some soldering yourself, you will have to find some help - it took me about 25 min to do the repair myself. Printer works great now.
Hope it helps..
Thanks for using fixya....
Oct 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C6180 All-In-One keeps restarting and won't power on. It cannot even be used as a photo copier nor does it allow for the computer to do anything to it as it has not been powered...
- Please check if it is connected to a wall outlet or to a surge protector...If it is connected to a surge protector then connect it to a wall outlet.....
Aug 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Dell all in one 942 ink jet printer reads "clear paper jam" there is no paper stuck. How do I fix?
Try this; Remove the cartridges, disconnect the usb cable, turn off the machine, unplug the power chord and switch off the adaptor from the wall switch, leave the machine for few minutes while you do some cleaning, like cartridges contact points, clean the rear panel door, also open the front panel door and check for any foreign particles, you should remember that even a small/tiny piece of thread or hair can create this problem. Now connect the power chord, switch on the wall switch, and power on the printer without the cartridges installed and the usb cable connected. Use the Power Button the switch on the printer. Leave it Switched On for few minutes and again turn it off, install the cartridges, connect the usb cable and again reboot the unit. Press the power button once and again keep pressing when it starts booting. If the problem still persists, your printer needs service.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | Dell 942 All-In-One InkJet Printer
I need to reset my canon mp620 printer and it is asking for a pin, i don't know what it is. do you?
Remove everything including Power chord, usb cable, cartridges, etc and turn it off again switch on only with the Power chord connected. Turn it off and then reconnect everything, power on and press the Power button repeatedly. This will reset you cannon printer. Thanks for using FixYa.
May 31, 2010 | Canon PIXMA MP620 All-In-One InkJet...
My computer smell like smoke and the power want come on? What to do?
your SMPS needs to be changed, its a small box ( switched mode power supply )
can be replaced by yourself. just open ur CPU .. find the place where it connects the Power chord, it should be going through a Small box SMPS .. remove it and take it to computer hardware shop , they would get you new one
Make sure you switch off your Power and unplug your power chords, its high voltage dangerous,,
Sep 02, 2009 | Dell OptiPlex GX520 PC Desktop
Power supply cable
The power cable using is the normal 3 pin power chord used on computer.
U need to check the power chord and the wall socket...
Jul 24, 2008 | Toshiba DP80F Printer
Epson STYLUS CX3900 All-In-One InkJet Printer Logo
135 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
